Author Topic: RD350 Dirt Tracker  (Read 125236 times)
Offline oldyzman
  • 250 two stroke!
Re: RD350 Dirt Tracker
« Reply #165 on: April 02, 2014, 07:59:59 pm »
Thats really looking good Yamaico, will we see this racing at nepean at some point?
Offline yamaico
« Reply #166 on: April 02, 2014, 09:11:25 pm »
Your not mucking around Pete
Looking good
Pressure's on Graeme, Broadford's only a little over two weeks away :P
Thanks Brett. Will definately run it at Nepean, hopefully I can use Broadford to sort it out. It should work good at Nepean, I reckon.
Offline SlideRulz
  • Not anti social just anti idiot.
« Reply #167 on: April 02, 2014, 10:38:10 pm »
Charity meeting 25 lapper sounds like the go ;D ;)
Offline yamaico
« Reply #168 on: April 03, 2014, 10:59:02 am »
Might have to train for that one Steve ;D
Offline Sorelegs11
« Reply #169 on: April 04, 2014, 11:02:46 am »
You'll be right it only lasts for a bit under 15 minutes,  ;)
Offline Dungar Pilot
« Reply #170 on: April 04, 2014, 11:20:20 am »
Whats this about the el cheepo challenge, i am trying to build a bike right now for sub $2k
2K is a positive kings ransom for Yamaico Pete. I think he's aiming to bring this in at $800 or less. The challenge involves the TM/TS250 Suzuki I built using the old mate network and skip bin parts and my stored away stash for $100 that we covered in a couple of early VMX editions. The bikes sat doing nothing since not long after it was completed so I'm very slowly converting it into a flat tracker to give to a mate who's doing it tough for Christmas this year. The same el Cheapo concept that I used to originally build the bike and that Pete has taken to new levels is being used. Once I get a bit further into it I'll post some progress shots.      Below, the $100 TS250 powered TM250 that'll soon be a flat tracker.
Hi Mate,
Wondering if you or anyone else can help me as I am after a TS/TM 250 clutch cover and actuator the same as the one in this photo?
Thanks in advance
Simo63
« Reply #171 on: April 04, 2014, 11:26:11 am »
Hi Mate,
Thanks in advance
I might have a spare one of those TM clutch side covers.  Will check and get abck to you :)
« Reply #172 on: April 07, 2014, 01:26:03 pm »
Hi Simo63,
Sounds unreal, Thankyou!
Offline SlideRulz
« Reply #173 on: April 07, 2014, 07:11:51 pm »
Darren's right Pete, 15 min max and if you get lapped a few times like I did you're only doing 22 - 23 laps.
Doesn't sound as bad. :o
Offline Sorelegs11
« Reply #174 on: April 08, 2014, 03:40:47 pm »
Should be right on the RD for the whole 25, I rode an SL175 in pre75 last year and got 22 laps in and she wouldn't rev past 8000  ;)
Offline yamaico
« Reply #175 on: April 08, 2014, 04:32:51 pm »
 ;D ;D ;D ;D
Got the engine assembled and most of the chassis together but finding it hard to get enough sunshine to put some clear on the tank and seat. Might have to use a mates booth to get it done. Aside from that just the carbies, chain, cables etc. to go.
Offline SlideRulz
« Reply #176 on: April 08, 2014, 05:12:10 pm »
As usual you're putting the rest of us to shame Pete, looking real good.
Hey Darren, do SL175's ever rev to 8,000? :o
Offline Sorelegs11
« Reply #177 on: April 08, 2014, 06:08:30 pm »
Year Steve its got 10500  redline but for one or two laps there must have been a bit of tailwind on the back straight and it actually got to 8!
Damn that RDs lookin Gooood.
Offline yamaico
« Reply #178 on: April 12, 2014, 04:18:47 pm »
Got the pipe mounting brackets finished and gave the pipes a coat of "pot belly black",
Also finished the stickers made up and then got the tank and seat cleared.
Just need to make a couple of reed spacer blocks, overhaul the carbies and put everything together and then give it a run.
Offline frostype400
« Reply #179 on: April 12, 2014, 05:54:09 pm »
Looking great. :)
1971 tm400 and PE's
