Author Topic: RD350 Dirt Tracker  (Read 125234 times)
Offline pancho
Re: RD350 Dirt Tracker
« Reply #135 on: March 15, 2014, 10:06:57 am »
Pete, have you noticed that there is 6600 views of your thread?
You are an Internet star!!!!
Must be a record! Keep it coming!
cheers pancho.
Offline yamaico
« Reply #136 on: March 15, 2014, 08:09:32 pm »
I'd like to think that was the case Graeme but I reckon that the "dirt tracker" in the title gets rounded up by search engines. Either that, or my family are being kind to me and hitting it regularly...
Got the second header pipe made last night so I should be able to finish the pipes over a few nights next week.
Once they're done just need to get the right footrest bracket and the rear brake pedal made up. It's a bit busy in that area so I'll probably go with a cable rear brake. Have to find a front mounting point for the rear brake torque arm as well, but once that's all done it can be pulled down to start all the painting, powdercoating, zinc plating and polishing.
Polished up the oil pump cover which came up pretty nice so I'll probably go with polished covers, soda blasted crankcases and black heads and cylinders with the fin edges polished. I'd like the raw look on the heads and cylinders but they are quite corroded and I don't like using glass bead on any engine components.
About five weeks until Broadford so should be OK, hopefully.
Offline yamaico
« Reply #137 on: March 20, 2014, 09:50:23 pm »
After burning the midnight oil a couple of nights this week just about got the piped finished. Still need to get some perforated steel and make the mufflers and weld the baffle cones on once everything is in place. Then it's just the hanger brackets and that job's done. Making the two pipes was certainly a challenge, but they fitted up OK in the end.
Should get the pipes and right footrest and brake pedal finished this week so it can than be pulled down and the painting can start, along with the front fork mods and the engine rebuild.
Offline JAP 454
  • See Ya at the Skids
« Reply #138 on: March 20, 2014, 10:46:34 pm »
It's lookin' the goods, Pete
Foss
« Reply #139 on: March 20, 2014, 10:55:34 pm »
Hey Pete, if you're doing the tank in Yellow Yamaha race colours I've got a graphics kit to suit a Champion tank that you may be able to copy. When you pick up my tank I'll give it to you.
Actually, I'm only using the tank graphics so you can have the seat decals.......PM me matey.
Offline yamaico
« Reply #140 on: March 20, 2014, 10:59:32 pm »
Foss
Thanks Al, she's getting close.
Offline yamaico
« Reply #141 on: March 20, 2014, 11:07:34 pm »
This one's going to be blue and white Mark. Thanks for the offer anyway.
Pete.
Offline SON
« Reply #142 on: March 20, 2014, 11:27:49 pm »
Blue / White still should have the Black / White BUMBLE BEE stripes Pete,
But I suppose since you went to this much effort,
you get to chose what colour it is !
Offline SON
« Reply #143 on: March 21, 2014, 06:37:56 am »
Yamaha Roadracer Callum Spriggs has a white R6 with the blue stripe with the black pinstripe
I think it needs the squares/rectangles to finish it off
Anyway Pete looking good
Offline yamaico
« Reply #144 on: March 21, 2014, 07:21:40 am »
Couldn't agree more Graeme - if you look closely at the picture you'll see the bumble bee stripes pencilled in on the tank and seat ;)
« Reply #145 on: March 21, 2014, 09:47:00 am »
Looking Great, well done ;)
Offline bazza
« Reply #146 on: March 21, 2014, 12:25:26 pm »
Looking  good  Pete
Embrace patina
Offline Matador107
« Reply #147 on: March 21, 2014, 10:22:58 pm »
Bultaco Astro 1972, graphics and leathers design by Royal Sherbet and rider Mike Kidd to run AMA flattrack. Kenny Roberts 1975, Tz750 champion frame shadow block or strobe block graphics ( bumble bee)designed and painted by Mike Viss.
Who was first and who's telling porkies, looks pretty net though.
Bultaco Metralla, Matador MK 5, Montadero mk2, El Bandido model 18,plus lots of bits and two Honda XR's 250,350.
Offline SON
« Reply #148 on: March 21, 2014, 10:52:07 pm »
Slight Hijack, what's the Royal Sherbert / Mike Kidd designing the Astro graphics on Royals kitchen table got to do with Pete's colours ?
Offline Matador107
« Reply #149 on: March 21, 2014, 11:38:19 pm »
Bultaco flattracker graphics on a Yammy that's all.
