Author Topic: 2011 VMX Nationals  (Read 371074 times)
Offline EML
Re: 2011 VMX Nationals
« Reply #495 on: August 24, 2011, 08:54:49 am »
I thought you would use hot rocks to keep stuff warm in SA
« Reply #496 on: August 24, 2011, 11:09:08 am »
Sorry NO qualifying.  Sorry  but i have always thought heats and qualifuing was a pile of shit.  IF someone puts there entry in in JUly, books holidays, travells 2,000 KM and then dont qualify even if they dropped a chain in practice on the thursday/fri.  Why after they have done the rioght thing for 4 months, should they be denied the ride.......
Unfortunately the lesson for the 2 in reserve ATM is read the supp regs and get you entrys in ealy so we can try to make adjustments Sooner, in the last days of entry you should realise you are cutting it fine anyway-  nuff said.
« Reply #497 on: August 24, 2011, 11:14:43 am »
Got the acceptance today with the program. Its all spelled out very clear , good job . Even tells you when to put your kids to bed .  :D   5 ,long lap races on this track will test any-ones  fitness thats for sure .
YEp tried to make it clear as possible so no one gets confussed about whats happening.
Everyone needs to Check there rider number on the last page of the final instructions if its not there check online incase your numbers have been changed to another preferance ( i rung most folks i think)
Also every one keeps asking for longer races so the later stuff has got 5 laps.  I think all the laps with races will even out so every class is about 10 mins or so long, that way we also get through the 72 events in daylight.
Also note sidecars are going across the hill, no sec hill so check track layout.
Also i just have to go into MA and pick up your one event licence as well walter so ill do that this week if i get a chance.
« Last Edit: August 24, 2011, 11:16:35 am by Freakshow »
« Reply #498 on: August 24, 2011, 11:21:07 am »
Freaky..How many has the pre65 got entered...Thanks A
BOTH AUSSIE TITLE CLASSes !!!!
Pre 65 solo 250cc
   1   John   Boag
   162   Ray    Atkins
   47   Kevin    Brown
   50   Colin   Metcher
   151   Troy    Moynihan
   46   Ian   wallis
   6
Pre 65 solo 263+ cc
   82   Nick   Maxfield
   145   Greg   Leaney
   264   Kell   Amberndtsson
   73   Steven    Dyjak
   152   Tony   Cavell
   350   Robert   Coates
   96   Rohan    Harris
   101   John   Budd
« Reply #499 on: August 24, 2011, 11:37:47 am »
It's good to see John Budd's name on the pre 65 entry list. John was one of the guns in the class back in the early 90's on his Triumph but has been MIA for years. I'm pretty sure he's from Mildura and had a bit to do with the first Vintage Dirt Track Nats back in the early 90's. Good bloke....and fast.
« Reply #500 on: August 24, 2011, 05:54:46 pm »
i nEED ONE MORE  PRE 78 125 OR 250 TO TICK THEM CLASSES  off THEN ITS FULL HOUSE aUSSIE TITLES FOR ALL !!!!!
« Last Edit: August 25, 2011, 01:37:33 pm by Freakshow »
Offline supersenior 50
« Reply #501 on: August 24, 2011, 09:36:14 pm »
Put the 70s in as the rule was intended [and corrected for 2012] and you've got your championship.
« Reply #502 on: August 25, 2011, 09:31:08 pm »
All  the bikes are now stickered up on white background with black numbers ,and someone pointed out today that the Husky needs green background and white numbers . How severe is that ? Does damien have to do them all again or is it OK  ? After all we have the transponders now ?
Sometimes in life we just have to do what that  @#$(&^%$#   MOM's GSR's book says to do and then there will be no numbers/background rule war.
Era percific and yep the transponders do break down and we need colours for class destinction.
Its a National title we need to look the part .  ;D
« Reply #503 on: August 26, 2011, 12:16:34 pm »
numbers and class letter need to be correct, backgrounds are essential as your colour will insure you in the right CC class.  I know its a pain but you can peel them off and save them for your modern bike.  i think you need to be green background and white lettering with a Y in there - but check before you get anything made this time.
the people on the start line and marshalling area dont see any transponder info, and this side of it all is really now for them to get you organised into the right places.  Right era, right cappacity right event.   ;)
« Last Edit: August 26, 2011, 12:22:59 pm by Freakshow »
« Reply #504 on: August 26, 2011, 12:18:25 pm »
Update for alison ::  ealry stuff is happening place !
Pre 65 solo 250cc
   1   John   Boag
   46   Ian   wallis
   47   Kevin    Brown
   50   Colin   Metcher
   151   Troy    Moynihan
   162   Ray    Atkins
   62   Des   Heaney
Pre 65 solo 263+ cc
   73   Steven    Dyjak
   82   Nick   Maxfield
   96   Rohan    Harris
   101   John   Budd
   145   Greg   Leaney
   152   Tony   Cavell
   350   Robert   Coates
   62   Des   Heaney
« Reply #505 on: August 26, 2011, 01:56:43 pm »
other option is colour the background in with a kids texta.  if its white it would be easy to colour in with a green texta permant or even water based. -  that would be an easy fix and Quite ok
Offline ARN
« Reply #506 on: August 28, 2011, 04:37:09 pm »
hi freakshow
how did the pre 78 classes end up as i was hoping to race 250 and 400
cheers arno  72
« Last Edit: August 29, 2011, 07:37:27 am by ARN »
Offline gdr
« Reply #507 on: August 29, 2011, 04:55:19 am »
freakshow,hows the evo and pre 85 125 classes going?.also thanks for the email,accomodation now booked. ;D
HONDA THE POWER OF DREAMS
« Reply #508 on: August 29, 2011, 11:32:45 am »
EVERY RACE IS NOW A SEPERATE RACE THERE ARE NO COMBINED RACES IN THE PROGRAM  ( 2 clases were cancelled instead - pre 60 and pre 75 sidecar) See timetable on back of instructions.
Everything is an Aussie title class "Except pre 78 250 at this time'  - but havent been into MA office today to see last online entries, but a few said they would.  so will confirm Subject to:
Program and " lastest Final instructions" are or will be on MA web site as soon as posible ifnot already.
pre 78 solo - 263 and over
   9   Mike   Waters   Suzuki   370   WA
   15   David    Footner   Suzuki    370   SA
   37   Victor   James   Bultaco   360   WA
   72   Arno   Franz   Yamaha   250   VIc
   100   Kris    Lindgren   Husky   390   WA
   130   Chris        Major   Yamaha   400   SA
   141   Brett    Bowen   Maico   400   Vic
   153   Jody    Smith   Maico   400   Vic
   154   Iain   Cameron   Yamaha    360   TAS
   372   Grant   Schubert   Suzuki   370   SA
« Last Edit: August 29, 2011, 11:39:25 am by Freakshow »
« Reply #509 on: August 29, 2011, 11:33:54 am »
Evolution solo - 125cc
   153   Jody    Smith   Honda   125   VIC
   258   Nicholas   Smith   Honda    125   VIC
   6   Don   Gabsch   Suzuki   125   VIC
   66   Robert    Ireland   Kawasaki   125   VIC
   108   Robert    Knee   Yamaha    125   TAS
   8   Peter   Shelton   Suzuki   125   SA
   247   Ben    Melvin   Suzuki   125   WA
   12   Grant   Dodd   Honda   125   Vic
   86   Noel   Lewis   Suzuki   125   NSW
   95   Graeme   Keogh   Honda   350   Vic
   W72   Benjamin    Ward   Yamaha   125   QLD
   20   Darrin    Buckby   Honda   125   SA
