Author Topic: DRM 400  (Read 78609 times)
Offline mposs
Re: DRM 400
« Reply #75 on: March 09, 2009, 09:03:49 pm »
Have scanned various Suzuki DRM370/400 articles from US dirtbike magazines over the years. Happy to post them up if anyone is interested.
Re: DRM 400
« Reply #76 on: March 09, 2009, 09:33:19 pm »
i would be interested to see the motorcross action DR 400 article
Offline ola_martin
Re: DRM 400
« Reply #77 on: March 09, 2009, 10:28:03 pm »
Me too!
Offline cloggy
Re: DRM 400
« Reply #78 on: March 09, 2009, 11:17:51 pm »
And me!
Anything you've got!
Offline YUMASTEPSIDE
Re: DRM 400
« Reply #79 on: March 10, 2009, 06:56:13 am »
............same here!    and thanks for the KDX article !!! ;D ;D ;D
Offline mposs
Re: DRM 400
« Reply #80 on: March 10, 2009, 07:49:01 pm »
Offline mposs
Re: DRM 400
« Reply #81 on: March 10, 2009, 07:56:00 pm »
Offline cloggy
Re: DRM 400
« Reply #82 on: March 10, 2009, 09:20:06 pm »
Brilliant, thank you so much.
Do you have anything for the later DR400?
I have a standard DR400 motor apart from cam , intake and exhaust mods and the clutch plates don't last too well on mine either!
Re: DRM 400
« Reply #83 on: March 10, 2009, 09:32:34 pm »
have you got the Motocross action DR400 article from 80/81?
Re: DRM 400
« Reply #84 on: March 10, 2009, 10:57:01 pm »
Leith, I've got the first part of it if thats any good to you.
        Roger
Re: DRM 400
« Reply #85 on: March 11, 2009, 07:03:53 am »
Cloggy , You need to put performnce clutch springs in . Change oil after every meeting as the cam tunnels are prone to wear .
Re: DRM 400
« Reply #86 on: March 11, 2009, 09:43:37 am »
Leith,
I think I have a part of that article...not sure which one but definatly not the first one.
Will check and let you know.
Offline cloggy
Re: DRM 400
« Reply #87 on: March 11, 2009, 06:21:23 pm »
Oldfart
Performance re company or performance adjective?
And which cam tunnels, for the cams or for the clutch, if so do you mean the tunnels in the outer casing?
I'm not being difficult, just thick.
I got the RMC swingarm finally sorted, it was internally sleeved and slightly widened, didn't have to repin due to the DR bearings being smaller external diameter. I was charged  for 1 hours work!
Re: DRM 400
« Reply #88 on: March 11, 2009, 06:59:19 pm »
re- cam , if you have altered duration and lift, you require heavier springs on top of valves (Eg performance springs )  mine obtained thru  Tighe cams of Brisbane .... AS the cam is opening the valves earlier and closing later ( valve overlap)   if the valve is lifting further  .....you WILL REQUIRE  heavier springs or you will get Valve float at high Rpm
Cam Tunnels .....groove in which your cam rotates in on head. Dirty oil is fed thru cam lube hole ( top of head ) which chews up the  cam and tunnel . This problem was then  overcome in  the  Dr 500 ,as they added a secound filter ( RHS case )
Offline cloggy
Re: DRM 400
« Reply #89 on: March 11, 2009, 07:25:33 pm »
Right OK
I've done at least 40,000 road miles with a Phil Joy [Protec copy] Road and Track grind
I use Protec alloy keepers and collets, I just got another set off USA ebay. I throw away the springs and use something that lasts out of a  Ford pushrod 1600cc performance catalogue. They cost peanuts [at least they used to] and unlike the Protec items they don't sack.
I've never had a cam journal surface pick up, though they do get rattly, but then I change the oil often. When the bike was my sole transport I used Rock oil. I was a despatcher for a while down in the smoke and oil changes on singles were a max of 1000 miles, any make/model or they knackered.
Of course this isn't competition, and we don't have the extreme heat that some of you get, so the engines don't work so hard.
The cam I have gets rid of the dip in the powerband in mid range. Phil can still grind one up. For more top end I grind off the intake weir in the head, that doesn't have much effect on carburation
I did briefly try the cam with standard springs but got bounce. The Protec grind has a bit more lift and a lot more duration but the DR top end doesn't seem to suffer from heavier valve springs knackering the journals.
Megacyle list for this model but the exchange rate has gone back up.....
I would like to source better clutch springs. The suzie items sack pretty fast.
