Author Topic: Sprite-UK/American Eagle-USA /Alron-AUST  (Read 735184 times)
Offline HuskyPete
  • Huskys Only, maybe a CCM
Re: Sprite/Alron/American Eagle
« Reply #555 on: May 19, 2010, 02:11:32 pm »
AJ's American Eagle, notice how much extra weight Frank Stanbrough has put in the crank to get the balance factor to 75%, the rest is coming together nicely.
Starting on the gearbox
« Last Edit: May 24, 2010, 09:57:20 am by 67Husky »
Offline vmx42
« Reply #556 on: May 20, 2010, 08:41:29 am »
Hey Pete,
I have always frozen the crank and heated the bearing to get the crank into the mainbearing. I have seen some 'crank pullers' [if that is the right word] but have never used one, is it a better way to go?
Or are the tolerances on these bearings too tight for freezing/heating to work?
Do you lube the crank before pulling it into the bearing?
Sorry, lots of questions, just really interested in your thoughts.
VMX42
Offline matcho mick
    • Moto Tumbi
« Reply #557 on: May 20, 2010, 11:12:56 am »
errr,isn't (hope ;D ;D) thats what the jar of vaselines doing in the piccie for?, :P
Offline vmx42
« Reply #558 on: May 20, 2010, 12:03:18 pm »
I did see that, but I wasn't game to mention it…
Offline HuskyPete
« Reply #559 on: May 20, 2010, 12:56:32 pm »
Jeff, i did indeed heat the bearing and freeze the crank just added a bit of vaso ;D to the shaft and used the crank tool to pull the crank into the bearing to make sure it was all the way home ;) makes the job easy using the right tools.
Offline vmx42
« Reply #560 on: May 20, 2010, 01:16:37 pm »
Hi Pete,
Thanks for the update. I only asked because I assumed that it would take a bit of time to assemble the crank tool and line everything up - by which time the temperatures of the bearing and crank would have equalised.
You obviously work faster than I do.
I might have to invest in a crank tool in the future as I agree that the right tools make life easier [even when it is me that is using them  :-\]. The ones I have seen are really just a steel tube with a threaded insert and an adapter to attach to the crankend. Nothing as elaborate as the one you use.
Lastly, I am assuming that the tool seats against the inner race of the bearing?
Jeff
Offline HuskyPete
« Reply #561 on: May 23, 2010, 04:56:49 pm »
Jonesy A/E all done
« Reply #562 on: May 23, 2010, 05:04:01 pm »
Beauty.....I can't wait to ride it at CD7.
Offline HuskyPete
« Reply #563 on: May 24, 2010, 10:14:48 am »
American Eagle/ Sprite Fallacy
The husky gearbox won't work in a Sprite/AE husky clone motor, at best you would have to change all the internals, crank, clutch, gearbox then maybe ??? ???
« Reply #564 on: May 24, 2010, 10:27:07 am »
Now you've gone and thrown a spanner into the works Petey! ;D Perhaps the Dongmeister can enlarge on what's needed as he apparently uses Husky trannys in his American Eagle racers.
Offline bazza
« Reply #565 on: May 24, 2010, 04:40:04 pm »
 pete the  motor looks good and as Freddy of Kellyville says "its all about style" catch up at C/D
Embrace patina
« Reply #566 on: May 27, 2010, 10:46:55 pm »
No wonder these bikes flopped. They were shite. Jonesys having all sorts of problems putting his AE together...nothing fits properly. Husky Pete had similar dramas with the engine. Now I've sat down and had a really good look at my AE (Sprite) frame, it's a seriously heavy bloody thing. There's no way they're made from Chrome moly, the wall thickness seems like 3mm. I'll try and weigh the frame over the weekend and will compare it to a Hindall, Cheney, Micro Metisse, Maico DT1 Yamaha and TS Suzuki frames. The results will be very interesting. My bets on the Sprite being even heavier than the TS frame.
The more we look into these bikes, the less inviting they become. That's why I like 'em ;D.
« Last Edit: May 27, 2010, 11:03:53 pm by firko »
Offline vmxken
« Reply #567 on: May 28, 2010, 06:13:54 am »
Reminds me of the fun I had taking mine apart.  The lower engine bolt on mine wouldn't come out unless I bent the bolt after it was half way out, so it would clear the frame.  It almost seems like they'd bolted the engine to the brackets and then installed the engine and welded the brackets to the frame.  Not looking forward to putting that bolt back in.
« Reply #568 on: May 28, 2010, 06:27:28 am »
  :o :o. Don't do that, you are reminding of working on Pommy cars of the period :-[. Ahhhhhhhhhhhh.
I think that period of the history of Pommy engineering was a high point in expediency and a low point of engineering excellence.
Offline JC
« Reply #569 on: May 28, 2010, 08:08:52 am »
These sorts of things are the same as I observed on the bike in NQ.
Symptomatic of what killed the pommie auto industry back then.
« Last Edit: June 01, 2010, 10:16:32 am by JC »
