CZ
Project Assembly
Pages:
4
5
6
7
12
Topic: Project Assembly (Read 33597 times)
490 tez
C-Grade
Re: Project Assembly
Reply #60 on:
May 22, 2009, 02:58:48 pm »
here is some cool machined stuff
big bore two strokes rock!!!!!!!!
Lozza
Reply #61 on:
May 22, 2009, 04:19:16 pm »
I often say I how I don't know how I would get by without a lathe and a mill of sorts. Only problem is you tend to run out of capacity very quickly, then need to purchase additional tooling(I dunno if this is the case with 5 axis).I would estimate double the purchase price of a mill will be what you will spend with tooling.Lathes are not as bad but still the tooling is required to get the most from it.
HERE
is a very good tool for the home workshop.Ji you need power feeds
Ji Gantor
Reply #62 on:
May 22, 2009, 06:29:47 pm »
Oh what the hell.
I made another pair of the dividing washers out of stainless steel this afternoon.
Just to show how to get the job done if you forgot something like the taper I have set up the following example.
Remember "Tool Of The Week"
It was the Toledo collet slide hammer puller for wheel bearings.
Well if you forgot to put the taper on the washers you can make a mandrel which will take time or just select the right size collet and place in the lathe. The collet holds the washer while you turn the taper onto the face.
Pretty cool hey.
Ji
Ji Gantor
Reply #63 on:
May 23, 2009, 11:17:52 am »
I have now cleaned, buffed and polished the engine to a state were I am happy with only 2 weeks to go before CD6. I have started to attach the case covers to see how they look.
It is all looking good.
Shiny happy
Ji
Last Edit: May 23, 2009, 08:47:07 pm by Ji Gantor
Ji Gantor
Reply #64 on:
May 23, 2009, 11:23:34 am »
The triple clamps have now been cleaned, buffed and polished.
They are now ready to be placed on the frame.
Ji
maicomc490t
Reply #65 on:
May 23, 2009, 05:53:05 pm »
Hey Ji - Come clean mate - you missed a few spots on the fins. Back to the Ajax and the tooth brush buddy !!!
The bike is shaping up to be one stunner - keep on keeping us informed.
Dave Mac
BTW - What is your next project after the one we are seeing taking shape ?
VAPOUR (AKA HYDRA / HYDRO / AQUA / WET) BLASTING AND GENERAL ENGINEERING 0416074750 (or)
[email protected]
BULTACO M49 parts wanted
paul
Reply #66 on:
May 23, 2009, 06:05:03 pm »
ive got one he can do
lol
Ji Gantor
Reply #67 on:
May 23, 2009, 07:22:29 pm »
I now have two steel and two stainless steel dividing washers.
Ji
Ji Gantor
Reply #68 on:
May 23, 2009, 07:26:45 pm »
The new plastic air filter box has to be fitted first into the frame before anything else so mark the holes and drill.
Ji
Ji Gantor
Reply #69 on:
May 23, 2009, 07:31:28 pm »
To get the air filter threaded rod to stand straight up inside the box I have to mill two nylon wedge shaped washers.
I am going to use 10mm thick millable nylon to make the wedges. I mark out what I require and with a scroll saw start cutting.
Ji
frostype400
Reply #70 on:
May 23, 2009, 07:33:48 pm »
all looking great whats the best stuff to use when polishing engine cases barrel and heads that airbox looks trick thanks Michael
1971 tm400 and PE's
Ji Gantor
Reply #71 on:
May 23, 2009, 07:34:29 pm »
I then place a belt sander upside down on top of a rubber mat so it does not move and sand the shape into the block that is required.
Ji
Ji Gantor
Reply #72 on:
May 23, 2009, 07:37:30 pm »
When I had the shape just right I then drilled a 6mm hole and deburred.
Deburr nylon with a stanley knife.
Ji
Ji Gantor
Reply #73 on:
May 23, 2009, 07:41:38 pm »
Very important.
To prevent the air filter nut coming loose and going through the engine drill a 2mm diameter hole through the threaded rod and twist some S/S safety wire.
Ji
Ji Gantor
Reply #74 on:
May 23, 2009, 07:44:41 pm »
With both nylon wedges shaped test fit in the box.
The threaded rod is now standing up straight like it should.
Looks great.
Ji
Pages:
4
5
6
7
12
CZ
Project Assembly
