Clubroom
Tech Talk
Fixing A Wheel
Pages:
9
10
11
Topic: Fixing A Wheel (Read 33683 times)
Ji Gantor
Re: Fixing A Wheel
Reply #135 on:
April 30, 2009, 11:12:49 am »
Once the paint has dried install the spacer into the wheel.
Ji
Ji Gantor
Re: Fixing A Wheel
Reply #136 on:
April 30, 2009, 11:14:22 am »
With rubber mallet and drift in hand install the new wheel bearing.
Ji
Ji Gantor
Re: Fixing A Wheel
Reply #137 on:
April 30, 2009, 01:58:37 pm »
To support the wheel while installing the wheel bearing a cradle is a handy thing to assemble.
Ji
Ji Gantor
Re: Fixing A Wheel
Reply #138 on:
April 30, 2009, 01:59:58 pm »
Install the seals on both sides.
Ji
Ji Gantor
Re: Fixing A Wheel
Reply #139 on:
April 30, 2009, 02:03:09 pm »
Place wheel into the truing jig and tighten the nipples as required.
Ji
Ji Gantor
Re: Fixing A Wheel
Reply #140 on:
April 30, 2009, 02:06:57 pm »
Clean the rim with shellite to remove grease and run the rim tape.
Ji
Ji Gantor
Re: Fixing A Wheel
Reply #141 on:
April 30, 2009, 02:09:41 pm »
Cut the rim lock and tube valve stem holes and install the rim lock.
Ji
Ji Gantor
Re: Fixing A Wheel
Reply #142 on:
April 30, 2009, 02:12:39 pm »
Mount the tyre.
Style with a tyre pen and give your new boots a spray with the tyre gloss.
Job done !
Two assembled wheels.
Ji
Ji Gantor
Re: Fixing A Wheel
Reply #143 on:
April 30, 2009, 02:18:06 pm »
Rear wheel before.
Ji
Ji Gantor
Re: Fixing A Wheel
Reply #144 on:
April 30, 2009, 02:23:47 pm »
Rear wheel before drum side.
Ji
Ji Gantor
Re: Fixing A Wheel
Reply #145 on:
April 30, 2009, 02:36:53 pm »
With the rear tyre on we can now check to see if it complies with rule
18.5.0.6
a) ii) Pre-1965, Pre-1970, Pre-1975- 5" (127mm).
Yep it looks pretty good to me I hope the scrutineers use the same tape measure.
Ji
Ji Gantor
Re: Fixing A Wheel
Reply #146 on:
May 01, 2009, 11:05:14 am »
To attach the new alloy sprocket to the hub there is a dilemma.
The old hardware is rusty and the edges on the hex have been rounded. I want to replace them with new S/S Allen Key socket head screws. The problem is that the old bolt has an M8 thread but steps up to 9mm where it locates in the hub and sprocket. The hex across the points is 13.4mm and can not be any larger or it will foul on the brake flange.
One solution is to purchase an alloy tube from Bunnings and some M8 hardware.
If you have access to a lathe turn down the tube to 9mm OD and tap an M8 thread inside your new sleeve.
Ji
Ji Gantor
Re: Fixing A Wheel
Reply #147 on:
May 01, 2009, 04:06:05 pm »
Place a length of alloy tube into the lathe.
Set the measurement and turn it down to the required diameter, in this case 9mm OD.
Ji
Ji Gantor
Re: Fixing A Wheel
Reply #148 on:
May 01, 2009, 04:07:49 pm »
Next secure an M8 tap in the drill chuck and feed it into the tube.
Ji
Ji Gantor
Re: Fixing A Wheel
Reply #149 on:
May 01, 2009, 04:10:26 pm »
Place the parting off tool in the tool post and part the length that is required.
Always use coolant when parting.
Ji
Pages:
9
10
11
Clubroom
Tech Talk
Fixing A Wheel
