Author Topic: Fixing A Wheel  (Read 33649 times)
Ji Gantor
Re: Fixing A Wheel
« Reply #120 on: April 28, 2009, 07:27:49 pm »
With the wheel bearings in we can now true the wheel.
Place wheel in the truing jig and check your work. If you have spent quality time working on the rim so far the truing will not take to much time. Remove any little side ways difference and tighten nipples to specification. If you are using an old rim they some times come with their own built in buckle no amount of truing can remove this.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #121 on: April 29, 2009, 07:30:38 am »
Dampen a rag with shellite and run around the inside of the rim to remove any grease and or dirt.
Once the shellite has dried place the rim tape or band onto the rim. I usually use electrical insulation tape and give the rim 3 to 4 layers to protect the tube from sharp edges on the spokes, nipples and the welded joint.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #122 on: April 29, 2009, 01:17:29 pm »
Rim locks are next.
I had to drive to four bike shops to round up this lot.
I prefer the rubber foot type rather than the CNC alloy ones just in case the alloy ones have a bur that might puncture the tube.
I also like the cap nuts because they stop dirt and water reaching the threads which seizes them on.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #123 on: April 29, 2009, 01:22:57 pm »
Unfortunately nothing is plug and play.
I find that these rim lock cap nuts will not screw all the way down so break out the tap and cut the thread a little deeper. Always use a cutting compound when cutting threads. I wrap the cap nut in 5 layers of masking tape to protect the anodizing from the vice jaws.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #124 on: April 29, 2009, 01:29:29 pm »
Start cutting the threads with a starter tap and finish with an end tap so the thread goes as deep as possible.
The caps now screw down all the way and are ready for use. Give the rim lock threaded rod a dab with anti-seize grease before use.
Keep the masking tape on the cap nuts until the rim lock has been tightened down so the gold stays where it should be.
Ji
« Last Edit: April 29, 2009, 01:49:42 pm by Ji Gantor »
Ji Gantor
Re: Fixing A Wheel
« Reply #125 on: April 29, 2009, 01:44:11 pm »
With a sharp knife cut the holes through the rim tape for the tube valve and rim lock.
Ji
« Last Edit: April 29, 2009, 01:48:03 pm by Ji Gantor »
Ji Gantor
Re: Fixing A Wheel
« Reply #126 on: April 29, 2009, 01:46:14 pm »
Install the rim lock.
The wheel is now ready for the tyre.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #127 on: April 29, 2009, 05:44:45 pm »
Mount the tyre onto the rim.
Set the tyre pressure to 15psi and leave over night. Check tyre pressure 24 hours later to see if you have pinched the tube.
Use a tyre pen to style the tyre and finish with tyre gloss.
There is a lot of work in a wheel and I am happy the front one is finished.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #128 on: April 30, 2009, 09:09:47 am »
Rear wheel.
Dig out the spacer and assess what needs to be done.
The spacer is rusty and the large wheel bearing firmly attached.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #129 on: April 30, 2009, 09:11:23 am »
Place the spacer in a vice and with a rubber mallet tap the spacer out of the bearing.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #130 on: April 30, 2009, 09:14:04 am »
To remove the rust off the spacer feed it into a bench grinder wire wheel.
Always wear eye protection during this process.
Depending on the tools you have use what you got.
Linish the spacer if you have a lathe, bead blast it or hand sand it with wet and dry sand paper.
Ji
« Last Edit: April 30, 2009, 09:20:09 am by Ji Gantor »
Ji Gantor
Re: Fixing A Wheel
« Reply #131 on: April 30, 2009, 09:16:52 am »
To prevent the spacer from rusting again I give them a coat of paint.
Clean the spacer with mineral turps and let dry in the sun, then apply a coat of etch primer.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #132 on: April 30, 2009, 09:52:41 am »
Find an appropriate socket or if you have a lathe turn up an alloy drift.
With the use of our trusty rubber mallet send the new bearing home.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #133 on: April 30, 2009, 09:54:08 am »
Replace the retaining circlip.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #134 on: April 30, 2009, 10:31:02 am »
After waiting an hour for the primer to dry apply a layer of top coat.
Ji
