Author Topic: Fixing A Wheel  (Read 32619 times)
Ji Gantor
Re: Fixing A Wheel
« Reply #105 on: April 27, 2009, 07:10:45 pm »
Hi Alison,
I was talking about the bench method that I was using as an example.
It is hard to see in the attached image but the rim should be kissing the packer when it is correct. In the image there is a gap of about 1.5mm. To lower the rim on to the packer loosen the upper nipples and tighten the lower ones this will drag the rim toward the packer.
If the rim becomes offset from the centre of the hub after a ride the best method is to leave the wheel on the bike and adjust the nipples to suit. To move the rim to the right loosen the nipples on the left and tighten the ones on the right. Do four at a time and work around the rim.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #106 on: April 28, 2009, 07:01:10 am »
The rear wheel is next.
The items in the attached image are all that is needed to lace a wheel.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #107 on: April 28, 2009, 08:41:25 am »
First place all the short spokes or the spokes on the drum side through the holes.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #108 on: April 28, 2009, 08:43:42 am »
Flip the hub over and fan out the spokes.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #109 on: April 28, 2009, 08:46:44 am »
Now place all the long spokes in.
I prefer to lace the long spokes first so that is why the hub is this orientation.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #110 on: April 28, 2009, 08:50:15 am »
Place the rim over the hub and lace the  outer spokes first. Fix their position by the nipples.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #111 on: April 28, 2009, 08:53:40 am »
Now lace the inner long spokes.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #112 on: April 28, 2009, 08:56:17 am »
There is no need to flip the wheel over just lace the drum side outer spokes.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #113 on: April 28, 2009, 08:58:23 am »
Last we lace the inner drum side spokes.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #114 on: April 28, 2009, 09:03:30 am »
Don't forget to use an anti-seize grease on the spoke threads.
The wheel is now ready to have the runout and offset jigged and the spokes tightened.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #115 on: April 28, 2009, 07:06:44 pm »
Front wheel first we now need to install the wheel bearings.
For those that don't have a lathe use a socket the same outside diameter as the bearing and with a rubber mallet drive her home all the way to the restricted flange.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #116 on: April 28, 2009, 07:08:46 pm »
Install the retaining circlip.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #117 on: April 28, 2009, 07:16:14 pm »
Install the spacer.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #118 on: April 28, 2009, 07:19:19 pm »
Flip the wheel over and with the socket install the second wheel bearing.
Ji
Ji Gantor
Re: Fixing A Wheel
« Reply #119 on: April 28, 2009, 07:20:59 pm »
Install both seals.
Ji
