Author Topic: HEEELLLLPPPP TS250X 1984 jet 6fjv54  (Read 14993 times)
Offline Timbo67
« on: April 04, 2018, 04:15:14 pm »
Hi Suzuki guys,
A very big thank you goes to James for helping out with a needle. I was being ham fisted with my old one whilst inspecting pit marks on the needle which I had never seem before. I too tried to work out tapers to match up with no success.
Tim
« Last Edit: April 11, 2018, 01:33:35 pm by Timbo67 »
Re: HEEELLLLPPPP TS250X 1984 jet 6fjv54
« Reply #1 on: April 04, 2018, 06:16:03 pm »
Tried any wreckers?
You could also try Show and Go.
Offline James P
« Reply #2 on: April 04, 2018, 06:57:40 pm »
See my reply in the Wanted section.
Regards,
James
« Reply #3 on: April 04, 2018, 09:27:26 pm »
Tell me the suzuki part number for this please and i will see what i can find.
Offline OverTheHill
« Reply #4 on: April 05, 2018, 05:54:30 pm »
https://www.cmsnl.com/suzuki-ts250x-1984-e-e01-e04-e17-e18-e21-e24_model14192/neelde-jet-6fjv54-4_1338313a00/#.WsbpJdTwYdU
Do you mean the 'jet needle' as apposed to the 'needle jet'?, another forum suggested try this crowd http://www.smebike.com/index.php?route=common/home
Have a look through these to maybe compare dimensions & might find something close. https://www.ebay.com/sch/Mikuni-Motorcycle-Jet-Needles/177773/bn_33498779/i.html?_fsrp=1
Offline Doc
« Reply #5 on: April 06, 2018, 05:10:26 pm »
Part number is 13383-13A00 jet needle. Indeed they are extremely rare.
Offline Andrew L
« Reply #6 on: April 06, 2018, 09:48:16 pm »
Better be more careful with mine when i pull it apart next time didn't realize they were so hard to get what about an necj needle from an rm250 have to be close
« Reply #7 on: April 07, 2018, 08:31:27 am »
not a lot of similarly btw the ts x and the rm. have you ridden them?
Offline Andrew L
« Reply #8 on: April 07, 2018, 11:56:37 am »
I have , I owned an 87 rm250 in the past and I own a ts250x 84 model , both have very similar flat slide mikuni but after looking at the parts list the needles for the rm are discontinued for it as well and the later ones have a keihn carb which the necj needle i suggested is from , so not much help there , maybe mikuni oz might suggest a similar replacement , the TM series carbs look the same
http://www.mikunioz.com/flat-side-carbs-non-pump/
http://www.mikunioz.com/product-category/jets/mikuni-jet-needles/.
« Last Edit: April 07, 2018, 12:16:43 pm by Andrew L »
Offline Wasp
  • Your Suspension Solution since 1989
    • Suspensionshop
« Reply #9 on: April 07, 2018, 02:12:21 pm »
I had exactly the same problem with the carbs on my triples . All jets and needles are Kawasaki parts and most obsolete or out of range  . There are only used mangled parts available on the net from USA or UK  at high cost . Got 3 new round slides from Sudco ( they look very similar to the OEM H2 carbs) . Now I can buy all the parts for tuning , cheap and new . The old 30 mm  carbs went on Ebay and I got  nearly as much for them as I paid for the new 32 mm Round slides. That made me and some purist happy . Just a thought .
VMX shocks , We don't just sell them - I design and produce them individually for you since 1989.
Offline cloggy
« Reply #10 on: April 09, 2018, 11:19:24 pm »
 I had the same problem with a SP370 jet needle It's a special made for suzuki part, not a standard mikuni part. Allens Performance knew the profile from the coding and also knew that there was no mikuni part which matched, or was even close as it was a double taper needle
