Author Topic: 1980 PE 250 tank  (Read 5034 times)
Offline kipo
1980 PE 250 tank
« on: July 13, 2016, 12:21:28 pm »
Just restored this 1980 PE 250 but usual story when i put fuel in the tank it split. The only thing I can find close is Just Gas Tanks and Clarke Tanks make after market for a 1980 RM 250 -400. Has anyone fitting one of these to a PE 250? Thanks for any advice.
Offline Terrapista
Re: 1980 PE 250 tank
« Reply #1 on: July 13, 2016, 12:37:23 pm »
Hi. If you go to page 3 of this forum theres heaps on your tank.
Good luck with it.
« Reply #2 on: July 13, 2016, 12:54:59 pm »
Offline kipo
« Reply #3 on: July 13, 2016, 01:51:13 pm »
Thanks blokes
Offline frostype400
« Reply #4 on: July 13, 2016, 06:27:05 pm »
Nice looking bike well done I think your better to leave it drained and cap off when not in use a lot do it seen yamaha it tanks do the same I have so many pe tanks for this reason but I think only one I have has split which was split when I got it.
1971 tm400 and PE's
Offline Oldfart
« Reply #5 on: July 13, 2016, 06:31:09 pm »
There is a product called Creme ( spelling ??)   that will line your tank.
I have used it, and works a treat.
« Reply #6 on: July 15, 2016, 10:45:53 pm »
http://www.kreem.com/fueltankliner.html
If its this one, i have used plenty of times in metal tanks and its fine for those but i am not so sure about using it in plastic tanks. The directions specifically say not for use in/compatible with plastic tanks.
