Author Topic: Rechroming Fork legs and shock shaft (yz mono)  (Read 15239 times)
Offline micko
« on: June 30, 2015, 07:55:44 pm »
Sorry if this has been asked before, Any suggestions who is good to deal with ?
Offline Mike52
  • 81 KTM 125 LC
Re: Rechroming Fork legs and shock shaft (yz mono)
« Reply #1 on: June 30, 2015, 07:59:18 pm »
RAD Hardchrome Brisbane.
Offline micko
« Reply #2 on: July 02, 2015, 04:10:37 pm »
Cheers, was trying to find someone in Perth to do it but they all look at you funny.
Off to rad it goes.
Offline alexbrown64
« Reply #3 on: July 02, 2015, 05:06:15 pm »
Your right there Micko.  Probably cost about sixty thousand dollars also.  I rang a place in Perth the other day about re-anodizing two old YZ rims and was quoted $300.
Cheers, Alex
Offline rob
« Reply #4 on: July 02, 2015, 07:03:20 pm »
RAD for hard chrome, spot on service !
Alex,
Call Collins anodic treatments 03 98774780 .
Regards
Rob WA.
Offline alexbrown64
« Reply #5 on: July 02, 2015, 09:52:42 pm »
Thanks for the heads up Rob, i will call them for a price when i build up my second wheel set.  I took my first wheel set rims up to Southern Powder coaters and they are blasting them and powder coating them gloss black for $20 for the pair. They are also only charging $20 for a set of hubs to be blasted and powder coated in satin black.
« Reply #6 on: July 02, 2015, 09:53:24 pm »
Check with Russ at Dynotime in Wangara - he recently sent my YZ fork leg off for me - it was a high build needed but a real good job.
Offline Brian Watson
  • First Penton in OZ
« Reply #7 on: July 03, 2015, 10:12:37 am »
Slightly off topic here.. but related to other posts here also..there is a guy in Landsdale (WA) that does anodising.. still a bit exy .. $100 a rim.. but was able to match old colour of Husky Nordisk rims perfectly.. a bit of a bear to deal with .. but well worth it in the end.. Brian at Camera Dynamics..9302 1316.. I  sand blasted the rims .. cleaned them up with a wire wheel. polished them on a pedestal buff.. I thought they looked. OK.. but still need to remnants of the anodising to be taken off with caustic..check him out..
Offline micko
« Reply #8 on: July 05, 2015, 11:16:22 am »
Shock shaft off to Rad,  even rang me after I sent an email to him. That's personal service to start with.
Offline Mike52
  • 81 KTM 125 LC
« Reply #9 on: July 05, 2015, 12:40:41 pm »
RAD appear to be expensive up front but when you consider that the re-chromed fork tubes will last a lifetime then it's worth it. ;)
Offline tymes
« Reply #10 on: July 05, 2015, 07:35:30 pm »
Has anyone been quoted or charged for pitted fork tubes, how much did they charge?
« Reply #11 on: July 10, 2015, 05:28:49 pm »
How much does RAD charge to do a set of forks that just have very minor little nicks/rust spots? I normally use www.hardchromeservices.com.au but i have some RM forks that i was not real keen on spending $400 on.
Offline rob
« Reply #12 on: July 10, 2015, 09:29:17 pm »
Example :
48mm KYB's with the axle lug's removed set me back $309.00 + $27.27 for FRT + GST of $33.64 comes to a grand total of $370.00 .
Shock shaft will come in at $100.00
Had my 73 YZ250A tubes done back 2007 by SA Hardchrome with an all up total of $300.00
Hope this helps
Rob.
« Reply #13 on: July 10, 2015, 10:05:38 pm »
Rad in Qld has done all my stuff, I'm in Melbourne.
« Reply #14 on: July 11, 2015, 07:38:26 am »
Don't think you can beat RAD's work or service. Excellent operators, pitted or not & will even do an express service for not much more money. There's no such thing as "cheap" hard chroming that's done right.
