Author Topic: 1975 Yamaha YZ50B Pistons  (Read 16765 times)
Offline melx
« on: April 27, 2015, 01:57:31 pm »
Hi all, I have a 75 YZ250B race bike on a standard bore that needs new piston kit, these don't seem to exist anymore, I have heard some bikes have a 5mm spacer fitted below the cylinder fitted and then run a Yamaha TY250 piston? I can not find any prior comments here on this. Can anyone give me a link or comment if this is a good solution? Is it as simple as adding the spacer or are other issues then requiring adjustments for? At least those pistons 74-75??) seem to be available for easy purchase.
74 CR125 KX125 TM250 TM400
75 CR125 YZ250B YZ360B
Offline Tomas
Re: 1975 Yamaha YZ50B Pistons
« Reply #1 on: April 27, 2015, 02:13:47 pm »
I would mesure the piston and see if there is anything that fits(you may need a spacer below the cylinder as you have mentioned). Here you find some piston dimensions http://www.mitaka.co.uk/CATALOGUE/PISTON_DIMS_ALL.htm   Wiseco,Wossner etc catalogue should also have piston dimensions. I think that you need a dealers catalogue. Not sure why I can not find the catalogue online. Good luck.
« Reply #2 on: April 27, 2015, 02:20:42 pm »
Mel - both Speed and Sport and NWVCP list various pistons - or alternatives - for the 250.  Speed and Sport listed more choices.
But be prepared to pay as they appear expensive.
Hope that helps.
regards
Rossco
Offline Momus
If you love it, lube it.
Offline OverTheHill
« Reply #4 on: April 27, 2015, 02:33:30 pm »
here in nz they were called mx250b in "75 & yz250c in "76 [just making sure we're talking the same thing [not earlier chrome bore DT1 shape motor yz monoshock], 509 pistons are still on fleabay 200981048071 or 380978576775 for a couple of starting points. Don't think you said what oversize [or i missed it] but anyway--hope this helps. The original yamy piston was a good strong one. Cheers, OTH.
Offline OverTheHill
« Reply #5 on: April 27, 2015, 02:53:18 pm »
couple more. not much use without rings though.
ebay 181098736414
http://www.cmsnl.com/mx250b-1975_model8540/piston-std-3rd-os_5091163701/#.VT29jcZcP5M
« Reply #6 on: April 27, 2015, 03:21:45 pm »
check the part numbers first as the 360 and 250 pistons are different and not just stroke variance.
MX 250b is a different bike but some of the pistons maybe compatible - they are between the 360's however have different piston cutaways/windows.  I think this is what North West will be listing.  Drop them an email - they are good to work with.
Offline melx
« Reply #7 on: April 27, 2015, 05:37:52 pm »
Thanks, I will try those references, I seen some advertise std pistons that list both 1975 250 and 360 YZ but obvious they are different bores. Seems on Yamaha parts they share the same part number which confuses. The ebay ones I got answers on were actually 360 pistons.
« Reply #8 on: April 27, 2015, 06:36:45 pm »
The trouble is with the numbers used the parts numbers are the same except the first 3 digits which are the model . Parts ziller lists start on the 4th mumber .
« Reply #9 on: April 27, 2015, 07:40:25 pm »
except - I have just noticed after Mels comment - NWVCP list 431 and 432 under both 250 and 360 - makes life interesting.
But as mentioned - write to them - they have been good to me in the past.
Offline melx
« Reply #10 on: April 27, 2015, 07:46:44 pm »
Thanks for that tip, it all makes sense now to me on part numbers now, I found https://www.motorcyclespareparts.eu/yamaha-parts/yamaha-model-prefix-motorcycles-1970-1994.aspx which lists the first part numbers to give the model. It shows :
431 is YZ250A
432 is YZ360A
483 is YZ250A
483 is YZ250B
484 is YZ360A
484 is YZ360B
using this reference the piston advertised now on ebay as std 250B piston has a part that starts with a 432 number so is in fact a 360 piston.
Offline sleepy
« Reply #11 on: April 27, 2015, 08:13:14 pm »
Wossner list the same piston for early YZ250 MX250 DT250 TY250 and IT250 they go in .5mm sizes up to 3 mm over. The one you need is 8179D050. PM if you need anymore info.
« Reply #12 on: April 27, 2015, 10:21:54 pm »
One question is it still a chrome bore . unless the bore has been re sleaved with a cast one you are in for a new cylinder or re chrome .
Offline YZB 500
« Reply #13 on: April 27, 2015, 10:28:49 pm »
Hi Melx,
I am not 100% sure but the YZ250B chrome bore barrels used the same piston as an A model 431-11631, I think the later in production B's model came with a bore able liner.
I think those piston were 431-11635 to 431-11638.
Be aware of the piston pin centre to piston crown height using pistons from 76 up era. I think the A model has a different piston crown height from the piston pin centre than the later B model 1975 MX250 & YZ250C model.
I converted my YZ250B to take the easier to find 509 piston MX250B, using a different rod than the YZ250B stock rod, the rod kit was from a later model YZ250 that pressed straight in No barrel spacers required.
I think the std YZ250B rod is 130mm centre to centre, using a later model piston you will have to spacer the barrel up from memory.
There is two types of head gasket for both the 250 & 360, a circle ring type and the other one with four 8mm stud holes and four head nut holes, not sure were in the production run these changes were phased in.
The 432 coded piston are 80mm Up for the 360cc motor, the Yamaha parts books of the era last something in translation, lots of errors in the books.
Regards YZB 500
« Last Edit: April 27, 2015, 10:45:13 pm by YZB 500 »
Old school is cool !
Offline OverTheHill
« Reply #14 on: April 28, 2015, 09:27:06 am »
pic of the bike would be good please just to be sure of the correct model. just google imaging yz250b 1975 it shows the DT1 shape motor [trick yz] i rode one for a year back then & has a chrome bore. Then googles mx250b 1975 & shows the next generation heavier [solid & reliable] different shape next generation motor which i had one of 'new'. This [cast bore] tales the 509 piston--boreable cylinder. Trick DT1 shape "75 has a chrome bore [originaly] so have to be careful with ring type [fkn stupid 'me' finished of a pretty stuffed DT1GYT kit cylinder by using wrong ring--wasn't happy lol. If your chrome bore has--had a liner fitted then maybe the 509 piston kit would work [think it would]. Thought the pin to top measurements were the same on all the reed valve 70mm yamy pistons but maybe not. Also be careful on ebay as they often say things like [fits 250 & 360] which it obviously doesn't [70mm & 80mm]. My rant for the day. Cheers.
