Author Topic: 1975 Yamaha YZ50B Pistons  (Read 16756 times)
Offline OverTheHill
Re: 1975 Yamaha YZ50B Pistons
« Reply #15 on: April 28, 2015, 09:31:43 am »
just closing the google images of the yz250b & saw a pic of the Harley mx bike with the front forks on the back--'what 'were' they thinking [plough a paddock lol].
Offline sleepy
« Reply #16 on: April 28, 2015, 10:12:59 am »
The Wossners that I mentioned earlier have a pin height of 33mm, that is from the centre of the pin to the top outside edge of the piston. The DT1 piston had a 28mm pin height which it seems the YZ A&B share. So without a rod change or 5mm spacer you are stuck with genuine os pistons assuming your bore is cast iron. The LA sleeve catalouge list a sleeve for YZ250 1973-75 and it has them as originaly chrome bores.
If you still have a chrome bore and go for a taller piston you will have to use cast iron rings or the chrome will be destroyed.
« Last Edit: April 28, 2015, 10:19:08 am by sleepy »
Offline OverTheHill
« Reply #17 on: April 28, 2015, 10:31:25 am »
i know there's a difference in height between piston port DT1 & reed valve from DT2--on [& YZ] but thought all reed ones stayed the same. Think i've dumped all my old pistons bugger it--don't ya just hate that. Cheers.
ps, got a pair of 250a/b crank wheels on trademe plus a [not too healthy] right side crankcase--think it's still up there!!.
Offline BA #63
« Reply #18 on: April 28, 2015, 11:56:27 am »
have you got a link for the yz stuff on tradme or the wording
I am still the fastest in the pits
Offline OverTheHill
« Reply #19 on: April 28, 2015, 02:18:51 pm »
  Hi, trademe auction number. Thanks.  879709939
