Author Topic: Kramit RV3 Rebuild  (Read 112551 times)
Offline KTM47
Re: Kramit RV3 Rebuild
« Reply #30 on: August 21, 2014, 10:23:32 am »
Noel,
Nice new project. Strange beast... never seen one of these before.
That puller is an odd size, 27mm x 1.25 is common enough however the 28mm is scarce.
I found one here: http://bit.ly/1rl38H3
And..... another one here:
http://www.trialsbits.co.uk/product_info.php?products_id=816
The UK might be your friend on this one.
Nice bike.
Jock
The puller shown here has an external thread.  Noel needs an internal thread.  However if that is all he can get you could make a long nut to screw to the flywheel and then screw the external thread puller to it.  It would work.
MAICOS RULE DESPITE THE FOOLS
Offline NSR
  • Sunshine Coast
« Reply #31 on: August 29, 2014, 09:53:23 pm »
Thanks for all your help.  I got the right puller from Floods.  Just under $100 bucks to get one part of the motor apart :o
At least I know it will last me forever ;)
Offline NSR
  • Sunshine Coast
« Reply #32 on: October 13, 2014, 10:54:53 pm »
Before I do this wrong.  What is the best way to remove these fork seals?
Simo63
« Reply #33 on: October 13, 2014, 11:09:37 pm »
I'll show you on Wednesday night at Bag's place.  Bring the following tools:
1) Hammer .. preferably a big one
2) Chisel .. and one of those long Stanley screwdrivers that you can hit real hard
3) 9 inch grinder with cutting blade fitted
4) Beer to show your gratitude :)
Offline foxy999
« Reply #34 on: November 04, 2014, 10:15:46 am »
nice ride bud, cant wait to see the end result !
My fastest lap is the first one :)
Offline NSR
  • Sunshine Coast
« Reply #35 on: November 10, 2014, 09:52:44 pm »
What is the best way of removing paint from magnesium? Can paint stripper be used?
« Reply #36 on: November 10, 2014, 10:00:54 pm »
Sandblast
Offline odd1
« Reply #37 on: November 10, 2014, 10:05:01 pm »
Water it will eat the magnesium from the paint!
Offline NSR
  • Sunshine Coast
« Reply #38 on: November 10, 2014, 10:36:27 pm »
  It sure does.  Just around where the pipes it has started to corrode.
Offline NSR
  • Sunshine Coast
« Reply #39 on: November 18, 2014, 10:26:47 pm »
Well it's all a bit ugly inside.  It had broken two of the shifter forks.  It looks like the motor has been fixed without buying one new part.
Simo63
« Reply #40 on: November 18, 2014, 10:36:04 pm »
Bloody hell Noel, that's dodgy as hell :(
Offline NSR
  • Sunshine Coast
« Reply #41 on: November 18, 2014, 10:43:31 pm »
And a very worn out big end Bering
« Reply #42 on: November 19, 2014, 08:51:32 am »
If you cant find someone good local to weld up your cases let me know.
Offline NSR
  • Sunshine Coast
« Reply #43 on: November 24, 2014, 09:34:00 pm »
Thanks Slakewell.  But its done.  The bottom end is now with my tame mechanic Peter Baguley to put together.
Offline Canam370
« Reply #44 on: November 24, 2014, 10:06:17 pm »
I like the clutch actuator. It looks better than the earlier mechanism - big rollers and a longer arm.
