Author Topic: Kramit RV3 Rebuild  (Read 112466 times)
Offline NSR
  • Sunshine Coast
Re: Kramit RV3 Rebuild
« Reply #45 on: November 24, 2014, 10:13:05 pm »
I wish my SWM had big balls :-[  I know you can buy the parts and do some machining to the case to make it fit
The Swvm though the tree's! http://youtu.be/4h6BbasT16I
Metalink Conondale vinduro sprint. May 19/20 2018
www.metalink.net.au  Bike trailers & Canopies
Offline NSR
  • Sunshine Coast
« Reply #46 on: December 09, 2014, 11:06:14 pm »
What is the real name for the rubbers that are holding the radiators on.  Does anyone have a lead on where they can be bought for a reasonable price?
Offline NSR
  • Sunshine Coast
« Reply #48 on: December 09, 2014, 11:44:13 pm »
Found em ::)  At 1/4 of the price I first got.  Thanks Lozza. But they look to wimpy, everything on this bike is industrial.
Offline Tomas
« Reply #49 on: December 09, 2014, 11:47:21 pm »
or even nicer looking piece http://www.ebay.com/itm/Maico-KTM-Husky-Bultaco-Penton-6mm-Exhaust-Rubber-Mount-/170532223818 and you can call it whatever you want as long as it fits  :)
Offline Canam370
« Reply #50 on: December 10, 2014, 08:12:49 am »
Check MCS online. They do a selection of mounts.
Offline sa63
« Reply #51 on: December 10, 2014, 01:40:17 pm »
The MCs ones do not last. believe me I tried most of them.
Offline Andrew L
« Reply #52 on: December 10, 2014, 04:05:05 pm »
Maybe try this mob , you might be able to make threaded pins for the recessed multicushion ones.
http://www.mackayrubber.com.au/products/vibration-isolators/
« Last Edit: December 10, 2014, 06:30:24 pm by mavman »
Offline gra1961
« Reply #53 on: December 10, 2014, 05:56:47 pm »
KTM KLASSIKER HAVE THE RADIATOR MOUNTS
« Reply #54 on: December 10, 2014, 08:34:14 pm »
cut the end of a set screw cut some fuel line and add washer and nyloc ?
Offline Mike52
  • 81 KTM 125 LC
« Reply #55 on: December 11, 2014, 07:18:05 am »
These ones work fine and break before your radiator
If you can't get the correct length then buy male/female ones and screw some allthread in the female end.
You probably knew all this Noel.
http://www.ebay.com.au/itm/5PCS-4mm-Rubber-Double-Ends-Screw-Anti-Vibration-Mount-Silentblock-/251709718892?pt=AU_Business_Industrial_Industrial_Supply_MRO&hash=item3a9b11816c
« Last Edit: December 11, 2014, 03:16:17 pm by Mike52 »
Offline NSR
  • Sunshine Coast
« Reply #56 on: December 11, 2014, 10:18:16 am »
Yeah, thanks guys got hold of some like Mike put up.  Even found one of the hard to get one for the SWM.  My local engineering shop wanted $25 a piece for them?
Offline Tomas
« Reply #57 on: January 31, 2015, 10:25:26 pm »
Any updates/pics?
Offline NSR
  • Sunshine Coast
« Reply #58 on: February 02, 2015, 12:07:34 am »
The frame is painted, New bushes and seals in the forks. One fork has the compression shim stack and the other has the rebound.  I'm not expecting great things from the forks.
The swing are and linkages are in.
Shocks had a full rebuild and a spec sheet filled out.  For not being opened since the late 80s the shock was in good nic.  should last another 30Yrs
There is ground in dirt in every part of this bike
« Reply #59 on: February 04, 2015, 11:01:57 am »
forks set up with rebound in one leg and comp in the other can be set up very very good nothing wrong with that set up
