Author Topic: Whats wrong with this bike ??  (Read 7510 times)
Offline VMX Andrew
Re: Whats wrong with this bike ??
« Reply #1 on: September 14, 2013, 06:55:09 pm »
The front forks having a trailing axle maybe??? ;)
« Last Edit: September 15, 2013, 07:03:35 pm by Tim754 »
Offline Graeme M
  • Administrator
  • Canberra, Australia
« Reply #2 on: September 14, 2013, 07:03:35 pm »
Yeah, looks like they put the front wheel/forks on round the wrong way...
Offline Vintmxman
« Reply #3 on: September 14, 2013, 07:33:47 pm »
Yep, front wheel mounted to wrong way facing forks..should be leading axle, not following axle...
Offline Canam370
« Reply #4 on: September 14, 2013, 08:42:48 pm »
Yamaha tried this with the XZ550 - didn't work for it either :P
Tony T
« Reply #5 on: September 14, 2013, 09:01:15 pm »
Are you serious, Paul?
I remember reading that they a heap of crap but surely they didn't really have a trailing axle???
Offline oldyzman
  • 250 two stroke!
« Reply #6 on: September 14, 2013, 09:13:15 pm »
She would be a bit twitchy down the straight...
« Reply #7 on: September 14, 2013, 09:14:26 pm »
What sort of retard would assemble the front end like that..? Other than Steve Wonder
Offline oldyzman
  • 250 two stroke!
« Reply #8 on: September 14, 2013, 09:18:05 pm »
The tyre would also hit on the rear of the front fender, could be interesting...
I wonder if the piston is facing to right way.
Offline OverTheHill
« Reply #9 on: September 14, 2013, 09:41:12 pm »
oldyzman prettywell covered my first thoughts--as in wouldn't like to be first to land it hard off a jump. Was a YZ80k on trade me [for ever] don't think it sold but [the old story] fully rebuilt, no cost spared etc--& forks in back to front. Worried me so much [new buyer gets injured] that i had to point it out diplomatically but never got a reply & pic never changed--give up.
Offline Canam370
« Reply #10 on: September 14, 2013, 09:44:06 pm »
You think I'd make that up? They surely did make a trailing axle :-[
Offline smed
« Reply #11 on: September 14, 2013, 10:01:04 pm »
Offline OverTheHill
« Reply #12 on: September 14, 2013, 10:52:07 pm »
xz400/550 was a pain in the arse, carbs were twin downdraft with accelerator pumps & hoses going everywhere. Were carb mods & airbox p**s flap updates early on. Flap was controlled by a vacuum diaphragm thingy that controlled the air at the airbox entry by memory. Reminds me--had one at work that someone had put sealer stuff in the tank & fueled it up too early no doubt, then this bloody cat piss smelling glue went through pretty much everywhere it could get in the carbs. The 550 was raced in the 6 hour over here [nz] but remember constant fiddling during the practice days before then think big ends the night before--not sure if it saw the 6th hour in the end. Steered weird too but probably 'mind over matter' because they look 'wrong'. Had a lot of offset [step forward] on the yokes so everything theoretically worked out with sliders reversed but i could never see the point in it apart from a gimmick [yamaha trickery]. Sorry getting off subject--what was it again!!].
« Reply #13 on: September 15, 2013, 07:15:19 pm »
Sold a pair off XZ550 wacko forks a an XZ enthusiast couple years back. He almost had a heart attack with excitement when I said is $20 to much??? Weird!!!
I still have the engine somewhere it is running a 45mm side-draft Weber carby.  Another one day project I will not get too...
In the parts that came with the wreck are the heaters that used to be in the leg fairings, they ran off the liquid cooling system like a car.
« Reply #14 on: September 15, 2013, 07:29:03 pm »
Tim, Tim, Tim, Maaate, you could turned them around and swapped them left to right and listed them as workx forks!! You could have sold the for for a $quillion mate ::)
