Author Topic: Rear sprocket Gaurd CMX/CDT  (Read 4746 times)
Offline Tossa
« on: March 15, 2013, 08:31:18 pm »
Been reading the new MOMS tell me if I'm wrong, it states:
12.8.8.6  Other than CMX/CDT a chain guard made of a suitable material must be fitted in a way to prevent trapping  between the lower drive chain run and the final drive sprocket at the rear wheel
that means to me no chain guard required!!!
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
Offline Ted
Re: Rear sprocket Gaurd CMX/CDT
« Reply #1 on: March 15, 2013, 09:48:32 pm »
It also doesn't list a bar pad for that era as being compulsary
81 YZ 465 H   77 RM 125 B
« Reply #2 on: March 15, 2013, 10:26:07 pm »
That's terrific, I've been holding off welding a brackets on my nice nickel plated swing arms until I could get the nerve to do it, now I don't have to. That's great news.
Offline Ted
« Reply #3 on: March 15, 2013, 10:30:16 pm »
So Mark, are the moms the gospel or can your local club make you fit one and a bar pad to ride club events. Who overrules who basically?
« Reply #4 on: March 15, 2013, 10:34:15 pm »
Don't take my word as gospel but I think MoMs rules over all Ted.
« Last Edit: March 15, 2013, 10:37:19 pm by firko »
Offline Tossa
« Reply #5 on: March 15, 2013, 10:38:14 pm »
it's also the same with footrests
12.8.5 Footrests other than CMX/DT Footrests must be:
a) well rounded and designed so as to ensure that no dangerous edges are created due to wear
b) Not touch the ground at lean unless they are hinged or pivoted and controlled by a return spring
In CMX it states up to and including pre 90 Folding footrests must be fitted nothing about springs!!
Offline Ted
« Reply #6 on: March 15, 2013, 10:48:03 pm »
No chain guard, no bar pad, no peg springs, GMC ultra lite pipe combo....this 125 will top out at 50 kgs....pity about the pilot :o
Offline Tossa
« Reply #7 on: March 15, 2013, 10:52:14 pm »
actually reading MOMs and I may not have found it including moderns the only bikes that have to have handlebar protection appear to be EVo, Pre85 and and pre90's and moderns  i might well be wrong but if someone can find anything different i would like to know
Offline Ted
« Reply #8 on: March 15, 2013, 10:55:44 pm »
Pre 78 down....no pads
« Reply #9 on: March 15, 2013, 11:40:24 pm »
Unless you punt them at a modern event ;)
17.2.1.3 Hooked brake actuating arms must have cable or rod securely fastened to prevent dislodgement........anyone got a zip tie?
Montynut
« Reply #10 on: March 15, 2013, 11:46:07 pm »
« Last Edit: March 16, 2013, 09:59:46 am by Montynut »
Offline Tossa
« Reply #11 on: March 16, 2013, 12:48:29 am »
Ted your local club does not require you to wreck your freshly painted illegal swingarm ;D ;D ;D to fit a guard.
BUT your local club does require a bar pad if you want to ride. It is in your local club rules that you signed off on when you joined the local club. Your local club is thinking of your dental costs ;)
I actually disagree with that based on the fact that the club is a member of MA and is bound to follow the rules and regulations laid down by the governing body and if you challenged the club ruling they legally would be left without a leg to stand on.
Much the same as Sup Regs can have special requirements club rules can add extra protection. Many Junior clubs required neck braces even though they are not required under the MOMS.
Montynut
« Reply #12 on: March 16, 2013, 01:09:19 am »
« Last Edit: March 16, 2013, 09:59:15 am by Montynut »
Offline gdr
« Reply #13 on: March 16, 2013, 09:23:49 am »
Have never seen club rules in my life ?
HONDA THE POWER OF DREAMS
Montynut
« Reply #14 on: March 16, 2013, 09:54:01 am »
OK no worries sorry for the thread hijack :-X
« Last Edit: March 16, 2013, 09:58:01 am by Montynut »
