Author Topic: Mugen  (Read 10009 times)
Re: Mugen
« Reply #15 on: February 27, 2013, 08:39:26 am »
Call it what it is bigk
Re: Mugen
« Reply #16 on: February 27, 2013, 09:28:45 am »
Mugen bikes were initially/mainly kitted bikes - it is a kitted bike.
Offline Tahitian_Red
  • Mugen ME480
Re: Mugen
« Reply #17 on: February 27, 2013, 09:37:30 am »
I have an engine with 360 piston which we've fitted into a standard cylinder, done the head & crank mods as well. The bike will have DG swing arm, GMC 360 pipe & RC style alloy tank. What should I call it? I also have an engine with a turbo crank, what can we call that one?
1. Honda BK360 kitted bike
2. Honda CR250 TURBO
 ;D
The "Factory Novice"
California, USA
Simo63
Re: Mugen
« Reply #18 on: February 27, 2013, 09:59:05 am »
Call it a YOSHIMURA HONDA MUGEN BIGKDGGMCRC 360
It will walk out the door for 35 K
Close Ted but it should be called a Mugen Honda BigKDGGMCRC 360 TURBO ... and will walk out the door at $35K  ;D
Re: Mugen
« Reply #19 on: February 27, 2013, 10:00:07 am »
A kitted bike would have the correct mugen pipe..
Offline 09.0
Re: Mugen
« Reply #20 on: February 27, 2013, 10:18:10 am »
And gear set and clutch springs. The big problem is the standard gears. They break with the kitted bike, same as the kickstart idle gear. All are beefed up with the full kit.
Offline flower pot racing
Re: Mugen
« Reply #21 on: February 27, 2013, 10:32:39 am »
Still a nice bike from what ever angle with what ever name.
The front and back end is rather nice.  If anyone wants a set of replica yokes for 44 or 43mm forks, I know where there are some and now with the stem so it's a bolt on affair.  Press the stem into the lower yoke and use your Honda bearing adjuster and top nut.  So if you want a later beefier 43mm front end with the better brake in your CR250 and while you are there have some exotic yokes to pull it all together on your pride and joy then PM me!  New shoxs can also be build from a stash of NOS parts that have been found, so fill your boots!
Wasnt someone in Nz making the shoxs and forks?  Thought I read that somewhere.  Does this bike have original or the new ones that were under construction in NZ?  Any ideas how that project is going?  It was mentioned on here a while ago.  Quite a bit of smoke and mirrors which I didnt understand...
Re: Mugen
« Reply #22 on: February 27, 2013, 10:36:09 am »
Exactly Brad, as I said earlier a lot of the 360's getting around only have a mugen top end fitted.. In my opinion they're not near as collectible as the real deal with the full kit fitted.
Offline suzuki59
  • Kiwi VMX
Re: Mugen
« Reply #23 on: February 27, 2013, 12:09:58 pm »
I seem to recall there were only around 10? full mugen bikes made?
But lots of people built /building kit bikes, of which this one looks to be a pretty good example.
Would be hard to see it fetching this kind of money in todays climate.
Offline Marc.com
Re: Mugen
« Reply #24 on: February 27, 2013, 01:48:12 pm »
Interesting collection of bits though, quite like the alloy airbox
Re: Mugen
« Reply #25 on: February 27, 2013, 03:00:03 pm »
Yeah it's definitely a nice bike, just a lot of money for what it is..
Re: Mugen
« Reply #26 on: February 27, 2013, 03:19:38 pm »
yeah don't argue with that JO - but it may not be a fully kitted bike but is closer than many got!  I had also heard with the 360 kit the gearbox was an issue.
Re: Mugen
« Reply #27 on: February 27, 2013, 03:44:28 pm »
I had a nice genuine Moto-x Fox 360 Mugen a while back Ross and didn't have any gearbox issues with it.. Another bike I probably should've kept!
Offline 09.0
Re: Mugen
« Reply #28 on: February 27, 2013, 04:04:27 pm »
Yes it would.
STW996
Re: Mugen
« Reply #29 on: February 27, 2013, 06:13:52 pm »
But if it was a full Mugen at 11.5 K AUS we would all be fighting over buying it! the other thing with Mugen you would need the history of the bike (a named rider of the day who had ridden it) that usually gets the price up. Plus what is the condition of the cylinder / piston would need to be good for that type of cash one would think?
