Author Topic: Interesting shed projects  (Read 12769 times)
Re: Interesting shed projects
« Reply #15 on: October 30, 2012, 12:20:10 pm »
Noise = power
The very same principle was applied to shorty mufflers
And politicians. ;)
Montynut
« Reply #16 on: October 30, 2012, 12:28:00 pm »
Noise = power
And politicians. ;)
 ;D ;D ;D Dam right
« Reply #17 on: October 30, 2012, 01:30:33 pm »
Must be a slow day at work.....I know a bloke who has a Canberra bomber in his back yard.....cool toy.....I reckon we should all chip in and buy one of the old army Iroquos choppers when the government finally gets round to selling them....how cool would that be to rock up to your next VMX meet in one of those....we could store it at GMC's ranch....I'm sure you wouldnt mind picking us all up Geoff...much easier than riding a DT400. ;D
Offline TooFastTim
« Reply #18 on: October 30, 2012, 01:59:08 pm »
There's a Canberra at HARS (http://hars.org.au/) in the "Gong. Looks fine (smaller than you'd think though) but isn't airworthy. Apparently it was used to take air samples after the A-bomb tests and, well, the decontamination process was a little too thorough.
« Reply #19 on: October 30, 2012, 03:54:31 pm »
And freak out any Vietnam vets that just happen to be there :o
Offline TooFastTim
« Reply #20 on: October 30, 2012, 04:02:38 pm »
Ya know as somebody new'ish to this neck of the woods I keep forgetting about the ANZAC involvement in that war.
Offline pancho
« Reply #21 on: October 30, 2012, 05:58:47 pm »
 O K. My simple question although well answered by HVA61, to me has not addressed the real qustion.
 If the forward motion was bought about by the pressure of lots of air sqirting out the rear and it won't work in outer space (primarily 'cause there's no air to go in the front) how come a rocket will work in outer space even though there is nothing to thrust against?
 Is there a mechanical engineer on here that can answer?
 I think I know how it works but I would like to hear an expert on this.
Cheers.pancho.
 P.S. not VMX but this is in the correct forum space I believe. (general discussion.)
78rm80c
« Reply #22 on: October 30, 2012, 06:34:55 pm »
What, your telling me none of you blokes have a jet engine in your shed??  ???
« Reply #23 on: October 30, 2012, 07:19:27 pm »
Um... building one from scrap in my shed. Have procured various pumps for the fuel and turbine bearing lubrication   :) Working on the fuel injection and metering/firing  chambers and afterburner now. Blokes got ta have a project. Thanks to the internet for the plans.... Tim754
Montynut
« Reply #24 on: October 30, 2012, 07:21:15 pm »
Cheers.pancho.
Laws of physics for each force there is an equal although opposite reactive force.
An example if you were in outer space and fired a gun (ignoring the fact that as there is no air would the bullet actually fire) the projectile would travel at a set speed in one direction and you would travel at the same speed in the opposite direction.
« Reply #25 on: October 30, 2012, 07:22:27 pm »
I've got a butane gas torch and a dog that farts....either of them cut it?
Montynut
« Reply #26 on: October 30, 2012, 07:24:25 pm »
A friend of mine built a jet engine using a truck turbo and a kero heater jet and AC plug ignition. It certainly propelled his billy cart fast in a striaght line and made the most unbelievable amount of noise so maybe GMC is correct. I kid you not ;D  ::)
Offline ksithumper
« Reply #27 on: October 30, 2012, 07:27:17 pm »
Every action has an equal and opposite reaction.
Google rocket principle and you'll get something like this:
With rockets, the action is the expelling of gas out of the engine. The reaction is the movement of the rocket in the opposite direction. To enable a rocket to lift off from the launch pad, the action, or thrust, from the engine must be greater than the mass of the rocket. In space, however, even tiny thrusts will cause the rocket to change direction.
One of the most commonly asked questions about rockets is how they can work in space where there is no air for them to push against. The answer to this question comes from the third law. Imagine the skateboard again. On the ground, the only part air plays in the motions of the rider and the skateboard is to slow them down. Moving through the air causes friction, or as scientists call it, drag. The surrounding air impedes the action-reaction.
As a result rockets actually work better in space than they do in air. As the exhaust gas leaves the rocket engine it must push away the surrounding air; this uses up some of the energy of the rocket. In space, the exhaust gases can escape freely.
Offline TooFastTim
« Reply #28 on: October 30, 2012, 07:40:18 pm »
Almost true. The law actually states: "for each reaction there is an equal although opposite reaction.
Not true. P=mv. Momentum is conserved so m1v1 = m2v2. The bullet buggers off at say 200m/s (v1) and it weighs say 0.05 kg (50 grams, m1) so P = 200 x 0.05 = 10. But you weigh 80kgs (m2) so 10 = 80 x v2 giving 0.8 m/s for v2 or the rate at which you bugger off backwards. See: http://en.wikipedia.org/wiki/Conservation_of_momentum#Conservation_of_linear_momentum
« Last Edit: October 30, 2012, 07:54:23 pm by TooFastTim »
« Reply #29 on: October 30, 2012, 08:11:29 pm »
Hmmm, so if gunpowder needs oxygen to explode how does the oxygen get inside the little brass chamber when it’s already full of gunpowder??
And the brass chamber is usually hidden away inside metal components making it hard for oxygen to get in quickly.
And if we sit things on our lap when we are sitting down where does our lap go when we stand up??
If only the forum intellect could be harnessed for good instead of…
