Author Topic: Interesting shed projects  (Read 12746 times)
Offline TooFastTim
« on: October 25, 2012, 07:19:15 pm »
Not the sort of thing you'd expect to find in chaps shed:
http://www.youtube.com/watch?v=qM7ksfRVF70&feature=related
Re: Interesting shed projects
« Reply #1 on: October 26, 2012, 05:08:53 am »
Bet his neighbours wished he'd stuck to noisy cars & bikes instead  ;D
maico police
« Reply #2 on: October 26, 2012, 06:27:12 am »
Hours of fun for the whole family there. ???
Maybe if he set up the kids 'slippery-dip' behind it and then fired her up........
« Reply #3 on: October 26, 2012, 08:49:17 am »
Awesome track blower before the next meeting....wont have any complaints about dust then will we.
« Reply #4 on: October 26, 2012, 09:29:10 am »
Bloody awesome, I want one.
Reckon I could fit that in a XT 250 frame
I look forward to winning Tattslotto so I can be the sort of eccentric that has that sort of stuff sitting around the yard.
Not quite in the same league but my old man had a BSA engine that he turned into a stationary engine, we used to fire it up every other year and watch it vibrate around the floor. These guys were smarter than my Dad though because they bolted their engine down.
Hasn’t been started in 20 years now at least, really must keep the family traditions going and embarrass my kid
Offline pancho
« Reply #5 on: October 30, 2012, 10:45:13 am »
 How many of us know why a jet engine moves through the air?
Offline HVA61
« Reply #6 on: October 30, 2012, 11:04:18 am »
BASIC UNDERSTANDING OF THE jET ENGINE PROCESS
The jet engines are essentially a machine designed for the purpose of producing high velocity gasses at the jet nozzle . The engine is started by rotating the compressor with the starter , the outside air enter to the engine . The compressor works on this incoming air and delivery it to the combustion or burner section with as much as 12 times or more pressure the air had at the front . At the burner or combustion section , the ignition is igniting the mixture of fuel and air in the combustion chamber with one or more igniters which somewhat likes automobile spark plugs. When the engine has started and its compressor is rotating at sufficient speed , the starter and igniters are turn off. The engine will then run without further assistance as long as fuel and air in the proper proportions continue to enter the combustion chamber. Only APPROX. 25% of the air is taking part in the actual combustion process . The rest of the air is mixed with the products of combustion for cooling before the gases enter the turbine wheel . The turbine extracts a major portion of energy in the gas stream and uses this energy to turn the compressor and accessories . The engine's thrust comes from taking a large mass of air in at the front and expelling it at a much higher speed than it had when it entered the compressor . THRUST , THEN , IS EQUAL TO MASS FLOW RATE TIMES CHANGE IN VELOCITY .
Offline TooFastTim
« Reply #7 on: October 30, 2012, 11:04:36 am »
and:
« Last Edit: October 30, 2012, 11:06:41 am by TooFastTim »
Offline Shaun G
  • Sydney, NSW
    • FULL LOAD MOTORCYCLE TRANSPORT
« Reply #8 on: October 30, 2012, 11:06:55 am »
Because it is attached to a plane  ;D
Shaun
« Reply #9 on: October 30, 2012, 11:08:10 am »
I crack a fatty when you rocket scientists are allowed to expound on the theory of thrust.  ;D
Offline HVA61
« Reply #10 on: October 30, 2012, 11:13:20 am »
Yes of course , forgot about that Shaun , it needs to be attached to a plane to gain the full value of the engine  ;D.
Although there are a bunch of English men that have a fully operational stationary jet engine setup in their garden. "Now that a real party toy."
Almost as good as a petrol powered blender , "hey Marky" 8)
Tony T
« Reply #11 on: October 30, 2012, 11:15:41 am »
I have trouble just comprehending the workings of a door handle...............  ::)
Montynut
« Reply #12 on: October 30, 2012, 11:34:29 am »
The objective of a doorhandle is to the convert rotary motion of your hand in................................................................................. ;D ;D ;D ;D :P :P :P :P
Or you could conceivable use the jet engine mounted on the cradle but it would most likely render the door to a one use only proposition.  ;D :P 8)
« Last Edit: October 30, 2012, 11:36:43 am by Montynut »
Offline HVA61
« Reply #13 on: October 30, 2012, 11:37:10 am »
to a exit or entry path   8)
« Reply #14 on: October 30, 2012, 12:06:11 pm »
The object of the jet engine is to make noise.
Noise = power
The very same principle was applied to shorty mufflers.
Noise needs atmosphere to travel.
Atmosphere is sucked into the front of the engine and turned into noise. The engine has big fans inside that amplify the noise and it is this noise that is expelled from the rear of the engine that creates the thrust.
Jet engines don’t work in outer space just like screaming doesn't.
If not bolted down the jet engine will move through the air.
We can easily take advantage of this by bolting the jet engine to a container that can carry people and merchandise.
