Author Topic: Stefans 495  (Read 4998 times)
maico police
Stefans 495
« on: March 17, 2012, 02:02:54 pm »
Luv these things....
KTM 495 Stefan Everts with Promax  G362TRC  and PD Forkvalves .
Re: Stefans 495
« Reply #1 on: March 17, 2012, 02:06:06 pm »
yep classic lines on those bikes, i am a fan of the great whites too.
Re: Stefans 495
« Reply #2 on: March 17, 2012, 02:13:48 pm »
It's gunna be worth the trip to watch him ride that thing around Farleigh... if it don't break ;)
Offline ba-02-xr
Re: Stefans 495
« Reply #3 on: March 17, 2012, 05:07:31 pm »
Amazing bikes. Point, twist & pray ;D
Re: Stefans 495
« Reply #4 on: March 17, 2012, 05:23:49 pm »
My uncle picked one of those up recently and thought the clutch was slipping up the straight, it was actually the wheel spinning
Re: Stefans 495
« Reply #5 on: March 18, 2012, 09:03:36 am »
Always amazes me how you use this site to plug your product....
Re: Stefans 495
« Reply #6 on: March 18, 2012, 10:00:06 am »
Those 495 are beastly , I would be very interesting to see how it's set up.
maico police
Re: Stefans 495
« Reply #7 on: March 18, 2012, 10:01:00 am »
It always is a pleasure to share
 :D :D :D
Re: Stefans 495
« Reply #8 on: March 18, 2012, 11:08:22 am »
We can always  make you a copy , now that we made the specs for first one , its easy .
I was far more interested in the motor set up, Ive only race, ridden a basic standard version which hits very hard and wheel spins to much so you put a huge Tyre on them and then they steer even worse. With a new modern ignition and pipe / carb set up I'm sure you could cure allot of that. For me thou personally Ill take a good 390/420 over the twin shock 495 any day.
Re: Stefans 495
« Reply #9 on: March 18, 2012, 11:15:13 am »
Use 2 base gaskets and 2 head gaskets, then retard the ignition 2 deg to begin with. You need to bias power to top end and make throttle response linear.
Re: Stefans 495
« Reply #10 on: March 18, 2012, 11:28:41 am »
If you use to much base gasket it changes the port timing to much and they hit harder because they dont run clean. Thicker head casket dose help / have played with the standard ignition timing, Flat slide elcetron tames it almost to much.
Re: Stefans 495
« Reply #11 on: March 18, 2012, 11:29:24 am »
I did that on the 360 Mugen i had.. smoothed out the explosive short revving power and let it it pull a lot longer in each gear.
Offline Canam370
Re: Stefans 495
« Reply #12 on: March 18, 2012, 12:14:16 pm »
 :D :D :D
Noice! :D
Offline ba-02-xr
Re: Stefans 495
« Reply #13 on: March 22, 2012, 08:28:13 pm »
Stay away Mick. I stll remember watching you on the main streight at Inverell ;). Claudine had to take you to the toilet. I bet you still feel it ;D.
