Author Topic: YZ 80E  (Read 20690 times)
Re: YZ 80E
« Reply #30 on: January 18, 2012, 07:37:26 pm »
the universal one should fit (like the ones on XR75's) it has a large left hand male fine metric thread.
if you undo the retaining nut you can see if there is internal thread "inside the flywheel" where the retaining nut was.
Offline steveo247
Re: YZ 80E
« Reply #31 on: January 18, 2012, 07:45:02 pm »
Retaining nut is now undone hoony, and the flywheel doesnt have an internal tread (that is for the bole type pullers right?)
Ill have a look for a universal xr75 type. The ebay special universal one dad has doesnt fit
Re: YZ 80E
« Reply #32 on: January 18, 2012, 10:39:00 pm »
Steveo247 , ask at any yamaha dealer or most bike shops the yz80 uses the standard yamaha flywheel puller . if you run your finger around the inside of your f/wheel the threads are very fine if covered in dirt or grease its likely you wont feel them .(tooth brush and wd40 )
Offline Billet YZ
  • Melton Victoria.
Re: YZ 80E
« Reply #33 on: January 19, 2012, 12:13:13 am »
As Hoony and iainyz has mentioned there should be a fine left hand thread in the centre of the flywheel, xr75 flywhell puller will fit that thread. Peter.
YAMAHA  you know you want one !!!  Viper #50
Offline YZ250H
  • Back in QLD Baby !
Re: YZ 80E
« Reply #34 on: January 19, 2012, 07:04:44 am »
Post a photo of it Steve so we can all have a look  ;)
Offline Billet YZ
  • Melton Victoria.
Re: YZ 80E
« Reply #35 on: January 19, 2012, 10:10:29 am »
It`s the last picture on page 2.  ;)
Re: YZ 80E
« Reply #36 on: January 19, 2012, 10:29:12 am »
WOW good work its all looking great, your doing a dam fine job, arya havin fun or what  :D
Offline YZ250H
Re: YZ 80E
« Reply #37 on: January 19, 2012, 10:29:29 am »
Thanks Pete.  pays to read the whole thread from where you left off last time  ::)
Super fine thread on the inside of the flywheel will definitely be there as per what everyone else has said.
I will shut up now  :-X
Re: YZ 80E
« Reply #38 on: January 19, 2012, 10:41:17 am »
ok now to move out of the Piano room so you blokes can get back to playing scales  ;).
Offline Billet YZ
  • Melton Victoria.
Re: YZ 80E
« Reply #39 on: January 19, 2012, 10:46:22 am »
Hoony,
          your`e trespassing don`t be throwing those broken cr500 cranks around in the Yamaha section.  ;D
Re: YZ 80E
« Reply #40 on: January 19, 2012, 11:08:11 am »
OOps sorry, did read all threads, sounded like the thread thing was well covered, so hey great job  :D looking forward to the future when the YZ80E is all together  ;)
Offline steveo247
Re: YZ 80E
« Reply #41 on: January 19, 2012, 08:05:33 pm »
Thanks gentlemen! Yes indeed there is threads in there. I had to look 2 or 3 times! the dirt n crap had almost made them invisible.
Will get em cleaned out and see how i go getting it off.
Re: YZ 80E
« Reply #42 on: January 19, 2012, 09:20:08 pm »
good luck mate, it looks rusty in there. let us all know how you get on.
Re: YZ 80E
« Reply #43 on: January 19, 2012, 10:48:23 pm »
This may sound a bit dodge, but I rigged up a piece of coathanger to clean out threads like this. You get an offcut about 200 mm long, bend it in half, then bend the last 5-10mm of each end in the opposite direction, so they oppose each other. Then you sharpen the two ends to a flat with a grinder and you've got something you can tension up so it bites into the threads a bit (by opening up the original loop) and twist around in an awkward spot like this to clean out the threads. It's not as good as tapping the thread obviously but it works.
Offline PEZBerq
  • Brisbane
Re: YZ 80E
« Reply #44 on: January 20, 2012, 08:07:32 am »
What other magic can you work using a coat hanger Dr Mainline?  ;D ;D Liberate locked keys from cars?
