Author Topic: Honcho head  (Read 13679 times)
Offline brent j
Re: Honcho head
« Reply #30 on: February 17, 2011, 11:37:59 am »
I've checked a TS90 head gasket against a TS100 head and they are different so sorry the Hodaka/Webco head won't fit.
The funny thing is the TS100 motor is a development of the TS90, the TS100 has a wider stud spacing on the cylinder but the head studs are closer together.
Brent
DR
Re: Honcho head
« Reply #31 on: February 22, 2011, 10:14:30 am »
this looks like it could be the go to make the little Honcho's a bit snappier..crank or rotor taper needs to be resized a touch but otherwise it appears a bolt on swap for the TS100 and I would assume TS90 also..maybe even TM75 :P
it's RM80 but from memory all the early RM's used the same stator..will double check that.. ;)
« Last Edit: February 22, 2011, 10:18:11 am by Doc »
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
Re: Honcho head
« Reply #32 on: February 22, 2011, 07:05:22 pm »
Watch it, Chris.  It seems the 4 screw affair is 'late' compared to the eight screw early variants. Got caught on my 80B.
You Really Should Have Known!
DR
Re: Honcho head
« Reply #33 on: February 22, 2011, 08:49:03 pm »
you know I never even looked what I bolted in Luke ::) normally don't have N or T stuff but someone must have sent me one ;D I've since tried the 8 bolt early '77/'78 RM80 and 250 stators and same deal, bolts up beaut. So long as the corresponding era CDI is used it should be okay yes... or am I missing the obvious?
DR
eBay Honcho - Orange NSW
« Reply #34 on: February 26, 2011, 08:49:25 am »
http://cgi.ebay.com.au/1975-Suzuki-TS100-Trail-Bike-/110652490425?pt=AU_Motorcycles&hash=item19c36702b9#ht_500wt_947
I'd chase it myself except I've a TS100 and 125 at Nambour to collect asap, 3 months on and I still haven't been able to get up to pick them up :( hope they're still there :-\
trailietrash
Re: Honcho head
« Reply #35 on: February 26, 2011, 01:06:28 pm »
Thanks for that Doc.... I have bike storage in Orange  ;D ;D
