Author Topic: were will i get these  (Read 7564 times)
Offline paul
« on: October 16, 2010, 09:17:40 am »
in plastic or brass  10 ml   maico breathers
TT
Re: were will i get these
« Reply #1 on: October 16, 2010, 09:34:51 am »
I would have said any decent plumbing shop would be able to match that.
Is the thread 10mm (looks too course for that) or the barb?
btw I've got a plumber living next door.  ;D
Offline brent j
« Reply #2 on: October 16, 2010, 09:48:05 am »
Failing a plumbing supplier try a hydraulic hose outfit, PIRTEK or ENZED etc
Offline wmc83
« Reply #3 on: October 16, 2010, 11:06:23 am »
Plumbing suppliers will only have that in 3/8 bsp if your lucky try a hydralic hose supplier
Offline wmc83
« Reply #4 on: October 16, 2010, 11:12:54 am »
Or a irragation outfit will do something like in plastic but metric thread might be a problem
Offline paul
« Reply #5 on: October 16, 2010, 01:05:36 pm »
ok ive tried these today ,nothing yet
pirtec
enzed
the hobby shop
motorcycle shop
bursons
old motor acsessory shop
reece plumbing supply
aquarium shop
irragation shop
Offline wmc83
« Reply #6 on: October 16, 2010, 01:26:24 pm »
Hmm engeneering supplier? Onesteel? I'm working with some downer edi guys next week I'll ask them if you like
Offline Billet YZ
  • Melton Victoria.
« Reply #7 on: October 16, 2010, 01:36:51 pm »
Paul, when you say 10 mm do you mean that`s what size spanner fits it or is that the hose size that fits it.  If a 10 mm spanner fits it then i would say the thread could be 1/4 npt as it looks to course to be metric. You should be able to get that fitting in brass at any bearing or air hose supplier. Peter.
YAMAHA  you know you want one !!!  Viper #50
Offline paul
« Reply #8 on: October 16, 2010, 01:52:19 pm »
peter 10 ml spanner /8 ml thread was what the guy at enzed said and they dont have them with that thread
Offline paul
« Reply #9 on: October 16, 2010, 02:11:43 pm »
Do you want me to make you one ?
i need 2  :D  please
« Reply #10 on: October 16, 2010, 02:26:58 pm »
Gas ...supplier should have then  ;)       ask for a barb outlet   8 mm Male iron
Or go another way  FI ....then ask for a hex nipple to adpt to both threads.
« Last Edit: October 16, 2010, 02:30:52 pm by oldfart »
Offline paul
« Reply #11 on: October 16, 2010, 02:28:14 pm »
ok i will this week if i dont find any in those boxes  i got from your place   ,thanks
Offline paul
« Reply #12 on: October 16, 2010, 02:31:24 pm »
Gas ...supplier should have then  ;)       ask for a barb outlet   8 mm Male iron.
  gas welding ?  like c.i.g or boac  something similar
« Last Edit: October 16, 2010, 02:48:08 pm by paul »
« Reply #13 on: October 16, 2010, 02:44:36 pm »
Sorry mate....  gas fitter supplier  =- LPG - NG - AC fittings                       If you go to any Reece joint looking for fittings of such it needs to be a HVAc store  http://www.reece.com.au/hvacr
Gas welding supplier  might ???       never had much luck myself.
Offline wmc83
« Reply #14 on: October 16, 2010, 03:33:54 pm »
The closest you will get in a gas fitting is 1/4" bsp I've never run into anything metric
