Author Topic: were will i get these  (Read 7556 times)
Offline paul
« on: October 16, 2010, 09:17:40 am »
in plastic or brass  10 ml   maico breathers
TT
Re: were will i get these
« Reply #1 on: October 16, 2010, 09:34:51 am »
I would have said any decent plumbing shop would be able to match that.
Is the thread 10mm (looks too course for that) or the barb?
btw I've got a plumber living next door.  ;D
Offline brent j
« Reply #2 on: October 16, 2010, 09:48:05 am »
Failing a plumbing supplier try a hydraulic hose outfit, PIRTEK or ENZED etc
Offline wmc83
« Reply #3 on: October 16, 2010, 11:06:23 am »
Plumbing suppliers will only have that in 3/8 bsp if your lucky try a hydralic hose supplier
Offline wmc83
« Reply #4 on: October 16, 2010, 11:12:54 am »
Or a irragation outfit will do something like in plastic but metric thread might be a problem
Offline paul
« Reply #5 on: October 16, 2010, 01:05:36 pm »
ok ive tried these today ,nothing yet
pirtec
enzed
the hobby shop
motorcycle shop
bursons
old motor acsessory shop
reece plumbing supply
aquarium shop
irragation shop
Offline wmc83
« Reply #6 on: October 16, 2010, 01:26:24 pm »
Hmm engeneering supplier? Onesteel? I'm working with some downer edi guys next week I'll ask them if you like
Offline Billet YZ
  • Melton Victoria.
« Reply #7 on: October 16, 2010, 01:36:51 pm »
Paul, when you say 10 mm do you mean that`s what size spanner fits it or is that the hose size that fits it.  If a 10 mm spanner fits it then i would say the thread could be 1/4 npt as it looks to course to be metric. You should be able to get that fitting in brass at any bearing or air hose supplier. Peter.
Offline paul
« Reply #8 on: October 16, 2010, 01:52:19 pm »
peter 10 ml spanner /8 ml thread was what the guy at enzed said and they dont have them with that thread
Offline paul
« Reply #9 on: October 16, 2010, 02:11:43 pm »
Do you want me to make you one ?
i need 2  :D  please
« Reply #10 on: October 16, 2010, 02:26:58 pm »
Gas ...supplier should have then  ;)       ask for a barb outlet   8 mm Male iron
Or go another way  FI ....then ask for a hex nipple to adpt to both threads.
« Last Edit: October 16, 2010, 02:30:52 pm by oldfart »
Offline paul
« Reply #11 on: October 16, 2010, 02:28:14 pm »
ok i will this week if i dont find any in those boxes  i got from your place   ,thanks
Offline paul
« Reply #12 on: October 16, 2010, 02:31:24 pm »
Gas ...supplier should have then  ;)       ask for a barb outlet   8 mm Male iron.
  gas welding ?  like c.i.g or boac  something similar
« Last Edit: October 16, 2010, 02:48:08 pm by paul »
« Reply #13 on: October 16, 2010, 02:44:36 pm »
Sorry mate....  gas fitter supplier  =- LPG - NG - AC fittings                       If you go to any Reece joint looking for fittings of such it needs to be a HVAc store  http://www.reece.com.au/hvacr
Gas welding supplier  might ???       never had much luck myself.
Offline wmc83
« Reply #14 on: October 16, 2010, 03:33:54 pm »
The closest you will get in a gas fitting is 1/4" bsp I've never run into anything metric
