Suzuki
RM125A piston
All
Topic: RM125A piston (Read 14237 times)
bigk
Kangaroo Flat Victoria
RM125A piston
January 04, 2008, 07:52:24 pm »
Can anyone out there in Sushi land tell me who can supply pistons or what the alternatives are for RM125A. I need a 1.5mm OS (57.5mm).
VMX Andrew
Re: RM125A piston
January 04, 2008, 08:01:04 pm »
try serco ...they sell a wide range of oversize pistons that covers all jap bikes....
Re: RM125A piston
January 04, 2008, 08:35:23 pm »
wiseco list 125 DS 1979-81
125 TS 1979-81
125 TC 1970-78
All having a 56 mm Bore X 50mm Stroke
56 std 449M05600 $108-00 as below
56.5 449M05650
57 449M05700
57.5 449M05750
58 449M05800 $118-00 price includes piston-rings -wrist pin and circlips
Re: RM125A piston
January 04, 2008, 08:35:54 pm »
Trailbikes of the same era might have more oversizes and may be the same shape. I did this on a TM125. I used something like a tc? 125.
bigk
Re: RM125A piston
January 04, 2008, 10:28:17 pm »
Tried Serco and the TC/TS thing, don't fit. They list RM125B onwards but no A model. Tried Pro-X,not listed either, tried a CR125 Elsinore piston, very close but different pin size. Someone who is into Suuki's must know the secret.
Lozza
Re: RM125A piston
January 04, 2008, 11:18:42 pm »
RM's were one of the first to go to the superior 54 X 54mm bore and stroke, to be a 56 X 50mm bore/stroke you probably have a 14mm pin. ProX has TS125 piston up to 58.50 in 0.25mm step and KE 125's have similar the TS has higher compression height and dome.
Last Edit: January 05, 2008, 10:47:30 am by Lozza
LWC82PE
Superstar
Re: RM125A piston
January 05, 2008, 10:04:03 am »
try BB importers/bikes and bits importers in WA they can fax you a diagram for you to fill in dimensions and they will try match it up to a piston from their huge stock. i dont have their phone number right now but i could find it for you. they used to advertise in VMX magazine.
TM BILL
Re: RM125A piston
Reply #7 on:
January 05, 2008, 01:53:00 pm »
RM 125A pistons were a one off 56mm std & 16mm gudgeon pin
there are usually loads on ebay because they only fit the RM 125 A
Re: RM125A piston
Reply #8 on:
January 05, 2008, 03:11:43 pm »
Not too sure on if this will work
Yz 125 1976-82 56mm-std 58 mm max 16mm pin
bigk
Re: RM125A piston
Reply #9 on:
January 05, 2008, 06:04:56 pm »
Thanks all, I'll let you know how I go.
Lozza
Re: RM125A piston
Reply #10 on:
January 05, 2008, 08:49:55 pm »
YZ's being reed induction probably have a window or a large cut away in the rear skirt.If it has a 16mm pin and you can't find a piston the you can always swap the rod for one with a 14mm pin.
Tim754
Northern Country Victoria
Re: RM125A piston
Reply #11 on:
January 05, 2008, 10:30:17 pm »
Big K , I got the Suzi parts book here for Rm125 models M, S ,A and B if you want to borrow. Tim754 (Elmore) PM if you do. Cheers.
Oldrodder
Re: RM125A piston
Reply #12 on:
January 05, 2008, 11:48:02 pm »
Try this web site
http://www.pistons-online.com
cyclegod
Sunny PERTH W.A
Re: RM125A piston
Reply #13 on:
January 14, 2008, 09:18:13 am »
This may interest you...
http://cgi.ebay.com/ebaymotors/Suzuki-RM125-nos-cylinder-set-1976_W0QQcmdZViewItemQQcategoryZ35581QQihZ007QQitemZ170185444473QQrdZ1QQsspagenameZWDVW
Ban BLACK rims NOW
bigk
Re: RM125A piston
Reply #14 on:
January 14, 2008, 09:32:24 am »
Almost got it soughted, just need to check a few measurements. Will post the results as soon as I confirm it will work.
All
Suzuki
RM125A piston
