Marque Remarks
Suzuki
RM125A piston
Pages:
All
Topic: RM125A piston (Read 15497 times)
bigk
Kangaroo Flat Victoria
Re: RM125A piston
Reply #15 on:
January 15, 2008, 03:44:42 pm »
I have found that a Suzuki TS125R piston is very close and will work by either running it with only the top ring or shifting the bottom ring locating pin.
K.
Re: RM125A piston
Reply #16 on:
January 15, 2008, 06:04:49 pm »
Nice one. Now that you mention it, i think that was the mod done to mine (move pin)
Doc
Re: RM125A piston
Reply #17 on:
January 18, 2008, 07:48:40 am »
BigK..the TS125R piston are a 14mm gudgeon opposed to the RM125A 16mm. Does this R designation point to a different (later) R? '71 and '94 were the only times Suzuki used this designation. (that I know of)
bigk
Re: RM125A piston
Reply #18 on:
January 18, 2008, 09:50:59 am »
Pro X part # 01.3007.200 listed to suit Suzuki TSR125. 16mm piston pin.
Doc
Re: RM125A piston
Reply #19 on:
January 18, 2008, 11:37:59 am »
okay..TSR..makes sense BigK..JDM model..this is a '96 model TSR125. Is there any property differences between an aircooled piston and a water cooled piston?? I never looked as anything bar air cooled thinking the watercooled may heat up faster and require different tolerances..
Last Edit: January 18, 2008, 11:41:07 am by Doc
bigk
Re: RM125A piston
Reply #20 on:
January 19, 2008, 08:50:46 am »
No difference in my experience in water cooled versus air cooled pistons. I have total confidence this piston will be fine. The bike is going to be raced, so it will be a good test.
Doc
Re: RM125A piston
Reply #21 on:
January 19, 2008, 12:45:47 pm »
I love to hear someone with oodles of confidence!
Thanks for the tip BigK, I can start looking at a whole swag of pistons and rings I'd previously overlooked
GMC
Broadford, Vic
Re: RM125A piston
Reply #22 on:
January 19, 2008, 04:36:32 pm »
Doc, I'm sure the alloy would be the same in all pistons (brand to brand)
Watercooled engines may have a different tollerance but this would be up to the guy that is boring it as they usually bore to suit the piston.
G.M.C. Bringing the past into the future
Lozza
Re: RM125A piston
Reply #23 on:
January 19, 2008, 07:59:11 pm »
Usually there is no real difference between air and watercooled pistons.Water cooled models just run more compression, with todays piston/machining technology you have little to worry about.
To use these pistions in old TM/TS you might need to swap to an RGV rod or such.
Pages:
All
Marque Remarks
Suzuki
RM125A piston
