Author Topic: RM125A piston  (Read 15495 times)
RM125A piston
« on: January 04, 2008, 07:52:24 pm »
Can anyone out there in Sushi land tell me who can supply pistons or what the alternatives are for RM125A. I need a 1.5mm OS (57.5mm).
Offline VMX Andrew
Re: RM125A piston
« Reply #1 on: January 04, 2008, 08:01:04 pm »
try serco ...they sell a wide range of oversize pistons that covers all jap bikes....
Re: RM125A piston
« Reply #2 on: January 04, 2008, 08:35:23 pm »
wiseco    list    125  DS   1979-81
                     125  TS   1979-81
                     125  TC   1970-78
                                                  All having a 56 mm Bore X 50mm Stroke
     56 std     449M05600           $108-00      as below
     56.5        449M05650
     57          449M05700
     57.5        449M05750
     58           449M05800         $118-00     price includes  piston-rings -wrist pin and circlips
090
Re: RM125A piston
« Reply #3 on: January 04, 2008, 08:35:54 pm »
Trailbikes of the same era might have more oversizes and may be the same shape. I did this on a TM125. I used something like a tc? 125.
Re: RM125A piston
« Reply #4 on: January 04, 2008, 10:28:17 pm »
Tried Serco and the TC/TS thing, don't fit. They list RM125B onwards but no A model. Tried Pro-X,not listed either, tried a CR125 Elsinore piston, very close but different pin size. Someone who is into Suuki's must know the secret.
Re: RM125A piston
« Reply #5 on: January 04, 2008, 11:18:42 pm »
RM's were one of the first to go to the superior 54 X 54mm bore and stroke, to be a 56 X 50mm bore/stroke you probably have a 14mm pin. ProX has TS125 piston up to 58.50 in 0.25mm step and KE 125's have similar the TS has higher compression height and dome.
« Last Edit: January 05, 2008, 10:47:30 am by Lozza »
Re: RM125A piston
« Reply #6 on: January 05, 2008, 10:04:03 am »
try BB importers/bikes and bits importers in WA they can fax you a diagram for you to fill in dimensions and they will try match it up to a piston from their huge stock. i dont have their phone number right now but i could find it for you. they used to advertise in VMX magazine.
TM BILL
Re: RM125A piston
« Reply #7 on: January 05, 2008, 01:53:00 pm »
RM 125A pistons were a one off 56mm std & 16mm gudgeon pin  >:( there are usually loads on ebay because they only fit the RM 125 A  :o
Re: RM125A piston
« Reply #8 on: January 05, 2008, 03:11:43 pm »
 Not too sure on if this will work
Yz 125 1976-82      56mm-std      58 mm max          16mm pin
Re: RM125A piston
« Reply #9 on: January 05, 2008, 06:04:56 pm »
Thanks all, I'll let you know how I go.
Re: RM125A piston
« Reply #10 on: January 05, 2008, 08:49:55 pm »
YZ's being reed induction probably have a window or a large cut away in the rear skirt.If it has a 16mm pin and you can't find a piston the you can always  swap the rod for one with a 14mm pin.
Re: RM125A piston
« Reply #11 on: January 05, 2008, 10:30:17 pm »
Big K , I got the Suzi parts book here for Rm125 models  M, S ,A and B if you want to borrow. Tim754 (Elmore)  PM if you do. Cheers.
Oldrodder
Re: RM125A piston
« Reply #12 on: January 05, 2008, 11:48:02 pm »
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Ban BLACK rims NOW
Re: RM125A piston
« Reply #14 on: January 14, 2008, 09:32:24 am »
Almost got it soughted, just need to check a few measurements. Will post the results as soon as I confirm it will work.
