Author Topic: 2011 VMX Nationals  (Read 371091 times)
Re: 2011 VMX Nationals
« Reply #405 on: June 01, 2011, 12:19:53 pm »
Tossa, there are issues with the online system, its set up for the modern and not as clear as it should be and the clasess dont work like we need them to.
i would promote sending in the old way and DL the form and post it, also you should send in your signed Scrutineering sheet anyway.  I will check your entry next week and if its not right ill flick you an email and we will fix it up.
Offline Tossa
« Reply #406 on: June 02, 2011, 10:21:44 am »
have received a confirmation of acceptance from SAMX and checked the link to their website and it shows as my entry being accepted so every thing appears ok so far!!lol.  Will get the rest of the stuff over to you.
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
« Reply #407 on: June 03, 2011, 12:24:20 pm »
Can i get a heads up of who is flying in and or flying there wivesin etc ?  Curious if we need to find out how best to get them up to the track and on what day ?  might be cheaper to hire a bus thats leave say XYZ on XYZ so it makes it easy for them to get around and also cheaper on the purse strings.  ITs a 2hr drive from town and 200KM so might be pricy in a hire car unless you get 500km included.
Anyone ideas here ??
Duanne you got people up there on this ?
Offline EML
« Reply #408 on: June 03, 2011, 05:40:53 pm »
I thought the club helicopter would fly down to get them??????
« Reply #409 on: June 04, 2011, 01:04:34 am »
OK your last up the hill then
Offline EML
« Reply #410 on: June 04, 2011, 11:39:04 am »
Either they are all C graders or that is one very steep hill.!!!!
Offline Duane799
« Reply #411 on: June 06, 2011, 10:17:28 am »
If they don't want to hire a car from Adelaide they can catch the Greyhound bus which stops at Crystal Brook or in Port Pirie. Or the Club Chopter can pick them up when its free.
« Reply #412 on: June 06, 2011, 10:34:15 am »
Looks like The Boys Hole at Mt Kembla first lap ;) :D.
« Reply #413 on: June 06, 2011, 12:18:19 pm »
Do you have any details on the bus service there.
« Reply #414 on: June 09, 2011, 01:58:34 pm »
For all you fly in freaks i have put up an edited  PREMIER Stateliner bus time table up in the locked thread,  so you can see if that helps you out any with your logistics for the wifey or if you plan to land in your self.
See post 13 #
http://ozvmx.com/community/index.php?topic=15670.0
« Last Edit: June 09, 2011, 02:02:21 pm by Freakshow »
« Reply #415 on: June 15, 2011, 04:10:28 pm »
Please dont use the online entry as its going to do your head in and miss classes.  why because it turns out its set up for modern motocross and they see only bikes per class not multiples.   Its too late to change it and the guy did it as a favour, so to save any embarrasment on the day when we only have you in one class.,  Please just post in your entry !!!!!!
We have over 30 entered already and some of the approved rider numbers granted are already up on the web site. So check all the tabs for your favourites to see if they gone and varients. ( tabs at the bottom left of the worksheet .  from 0 uyp to  #999 in blocks of 200)
http://www.motorcyclingsa.org.au/documents/readonlynumbers.xls
So check there to see if your number has goen BEFORE you post in your entry and please write a plan b -- 14,114, 141 etc -  otherwise you might not get any numbers by the time we get around to calling you for option or we might even make one up !!!
So get em on there.  so you can mess with the ones on  your bike already if its an issue.
« Last Edit: June 16, 2011, 12:32:24 pm by Freakshow »
Offline Duane799
« Reply #416 on: June 16, 2011, 11:01:33 am »
Try Spencer Gulf Coaches in Port Pirie 08 8632 2666 if you want to hire a coach
« Reply #417 on: June 18, 2011, 12:20:41 pm »
can somebody please load up the One Event national Historic Licence form as I can't access it or find it on the web site?
thank you
« Reply #418 on: June 18, 2011, 10:36:29 pm »
thank you
http://www.motorcyclingsa.org.au/documents/2011MSARidersLicenceApplication_002.pdf
ps:we don't have them in WA yet  ;)  ;D
« Reply #419 on: June 19, 2011, 09:39:59 am »
thanks Al.
