I think we need to stop the personal insults now!!!!
Here are the facts exact dates may not be correct but they are close. EVO was first run in Qld in the early nineties. When we started the ThunderX series the rules were in the sup-regs. The following are those rules.
"The Evolution Class is the same as the class in the USA (ie no linkage suspension, air cooled, drum brakes & no cartridge forks) most Twin Shock machines and Yamahas up to 1981 models (approximately) are eligible.
Note:- The machine must have originally been manufactured with Twin Shocks or No Linkage and be within the spirit of the class. "
I don't know what other states did or when they introduced the class.
Thumper Nats were running Twin Shock when it started but then changed to EVO and I believe used the same rules.
It wasn't until the 2004 MOMS that MA introduced the class. Those rules were written by the Commission.
I do believe the current rules need to change, but not to what has been proposed. I think all the current Classic MX & DT rules need reviewing, but only after proper consultation with Clubs who are involved in Classic MX
& DT.
I have found another section of the MOMS that gives a guide as to how things could go.
It may be too late to go back to what many may think the rules should be, but as I said previously, I'm sure we don't want the class totally bastardised. Also EVO has got and always has had an era. It is the period the machine was manufactured.
TBM I don't mind what you have proposed and that could be the basis for what might occur. Also EVO isn't the only class that needs clarifying.
Also I won't be posting on here or anywhere else what I may or may not submit to MA and I don't think anyone else should also.
This thread has been useful (apart from the personal attacks and name calling). I learnt a long time ago to ignore a lot of that shit, however every now and then I do snap.
One other point the proposed rule changes form the Commission want to change the age groups for the Aust Post Classic MX & DT championships from the EVO classes to Pre 85. Is that what we want?
![Huh ???](http://forum.ozvmx.com/Smileys/default/huh.gif)
Kevin
