Author Topic: Uknown CDI ignition system  (Read 14948 times)
Offline Colin Jay
« on: September 18, 2009, 04:10:04 pm »
All right all of you Suzuki people, while doing a bit of tidying up in my shed, I found the Suzuki CDI ingnition system pictured below.
I have no idea what it came off of or really how it came to be in my parts collection. All that I can think of is that it was in a box of bits that I got about 10 years ago when I bought my RV125.
The following detail are marked on the various bits;
CDI unit:  CU "?" 168
              32900 - 41420
Flywheel: KOKUSAN  FP6161   4192
Stator: M41674
Coil: 3181 CD 7C
The stator has lighting coils (orange and yellow/red wires).
My RV125 has points ignition and I dont think that the RV's ever came with CDI.
SO, any suggestions as to what this system came off of?
CJ
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: Uknown CDI ignition system
« Reply #1 on: September 18, 2009, 04:29:38 pm »
Looks like late 70's TS/TF125
Ban BLACK rims NOW
DR
« Reply #2 on: September 18, 2009, 04:54:47 pm »
I'd say PE250B/C '77/'78 and PE175C '78  ;)
« Reply #3 on: September 18, 2009, 05:51:17 pm »
PE early model
Is it forsale ???
RMJJ
« Reply #4 on: September 18, 2009, 06:29:04 pm »
The coil and the CDI are 100% 1981 RM125. The rotor and stator aren't. I don't think they are old RM. Old RM had internal rotors.
The coil was also fitted to the 1981 PE and probably other models. I don't know if the cdi was fitted to the PE.
« Last Edit: September 18, 2009, 06:50:48 pm by RMJJ »
« Reply #5 on: September 18, 2009, 06:45:49 pm »
I checked my 77 PE 250 B flywheel and it is FP 6167 4192
Cant read the stator as the numbers are gone because its been slotted where the numbers were for use on a 250 T.
can you post a photo of the ID of the flywheel so i can see the magnets? are they glued in? to me its looking like they are 78/78 PE175/250.
The CDI is 100%  off these models, not RM125 unless UK used the earlier PE stuff in the 81 RM125????
PE175C 1978
PE250B 1977
PE250C 1978
« Last Edit: September 18, 2009, 06:55:37 pm by LWC82PE »
RMJJ
« Reply #6 on: September 18, 2009, 06:58:01 pm »
Leith,
The CDI was fitted to the 1981 RM125. Its the only year it was fitted to an RM and the only RM model.
Check the part number if you like. The coil like I said above was shared with the PE. The CDI obviously was aswell.
« Reply #7 on: September 18, 2009, 07:22:57 pm »
well zedder x ref which is USA based lists this for RM125X
Part # = 32900-14120
Part Description = CDI UNIT
Model Count = 1
RM125-X 1981 124 RM125 OFF ROAD
Your an expert on the RM125 so are you saying the program is wrong? it might be but this backs it up
http://alpha-sports.com/smoto/1981%20RM125/11.htm
« Last Edit: September 18, 2009, 07:44:44 pm by LWC82PE »
Offline Colin Jay
« Reply #8 on: September 18, 2009, 08:51:27 pm »
Leith,
Battery just died on my camera, but there are 3 magnets inside the rotor and there is a "gap" bar seperating 2 of the magnets that is held in place by the phillips head screw that is just visible in the original picture. The magnets appear to be glued in place. Outside diameter of the rotor is 106mm inside diameter is 86mm (give or take a fraction)
CJ
« Last Edit: September 18, 2009, 08:55:57 pm by Colj500 »
DR
« Reply #9 on: September 18, 2009, 09:08:38 pm »
numbers below for the CDI's
32900-41420 '77/78 PE175C/PE250B/C
32900-14120 '81 RM125X
« Last Edit: September 18, 2009, 09:11:12 pm by Doc »
RMJJ
« Reply #10 on: September 19, 2009, 02:37:49 am »
Model Count = 1
You are right.  I am wrong. I need new contact lenses, getting the 414 and 141 mixed up.
Call me  dumb pom if you like  ;D
suzuki43
« Reply #11 on: September 19, 2009, 06:43:28 am »
DUMB POM!!! ;)
PS I hear you ride like a raging bull.
LOL
« Reply #12 on: September 19, 2009, 06:50:03 am »
Make him go and have a bath , that will be enough punisment ;D ;D :o
DR
« Reply #13 on: September 19, 2009, 07:20:03 am »
mmm :D have done the same thing myself RMJJ, even went so far as ordering the wrong part because I thought the number looked the same ::) I use reading glasses all the time now, they reckon at about 40-45 is when most peoples' eyesight starts to go down hill :( but not mine, mine seemed to go overnight soon as I turned 46! ::)
« Last Edit: September 19, 2009, 07:22:37 am by Doc »
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #14 on: September 19, 2009, 08:15:09 am »
Mine went downhill at 47 - I went in and within 45 minutes I was out and happy. seemed like someone switched on the lights.  He also said that anybody who gets to 50 without needing reading glasses is either a VERY rare bird indeed, or a vain dope :-)
now, some CDI part numbers for your enjoyment!
PE
                                        1977 PE250B 32900-41420
1978 PE175C 32900-41420                 1978 PE250C 32900-41420
1979 PE175N 32900-41421                 1979 PE250N 32900-41421
1980 PE175T 32900-40520 (30) RS175T     1980 PE250T 32900-40620       RS250T
1981 PE175X 32900-40531      RS175X     1981 PE250X 32900-40620 (30)  RS250X
                             RS175Z
1982 PE175Z 32900-14410
1983 PE175D 32900-14410
1984 PE175E 32900-14410
1980 PE400T 32900-40920
1981 PE400X 32900-40920
1982 PE400Z 32900-40920
RM
32900-41320       1976 RM125A,         1977 RM100B
32900-41321       1977 RM125B,         1978 RM125C
32900-41210       1978 RM100C,RM400C
32900-41111       1977 RM370B,RM250B,  1978 RM250C/C2,    1979 RM250N
32900-41112       1980 RM250T
32900-40220       1979 RM100N,RM125N   1980 RM100T,RM125T
32900-40420 (21)  1979 RM100N,RM400N,  1980 RM100T,RM400T
32900-40422       1981 RM465X
TS
32900-30511, 1977 TS185B,         1977-1981 TS250
