Author Topic: two tone paint  (Read 2808 times)
Offline jimson
  • Sanctuary point N.S.W
two tone paint
« on: September 06, 2009, 09:41:26 pm »
If I was to paint my tank two tone how do you blend the paint without the rise in the level to the next colour do you just spray clear over it as like a filler to cover the level.jimson
Offline jimson
Re: two tone paint
« Reply #1 on: September 09, 2009, 06:23:56 pm »
Common lad's someone out there must be a spraypainter  :( I want to paint the tank this weekend it would help if I new what I was doing.jimson
Re: two tone paint
« Reply #2 on: September 09, 2009, 06:59:03 pm »
Clear coat the tank after 2 toning then after drying rub it back with 1200 and clear it again. Be carefull not to rub through the clear or you'll have to repaint it. 2 pack or acrylic?
DR
Re: two tone paint
« Reply #3 on: September 09, 2009, 07:39:58 pm »
pinstriping can sometimes be of assistance also Jimson but you'll still have a ridge to contend with :-\
Offline RED ALERT
Re: two tone paint
« Reply #4 on: September 09, 2009, 08:42:51 pm »
Clear,sand,Clear,sand, clear,sand, clear,sand....BUff :)
Re: two tone paint
« Reply #5 on: September 09, 2009, 08:50:36 pm »
If it's 2 pack you can do it in a couple of applications and skip the Buff at the end if you're lucky.
Offline RED ALERT
Re: two tone paint
« Reply #6 on: September 09, 2009, 09:13:38 pm »
Yeah i know, I tend to be a bit fussy. The number of clearcoats depends on the edge your trying to bury.
A couple of coats is often enough but if your playing with flake and the like you need more.
Offline jimson
Re: two tone paint
« Reply #7 on: September 09, 2009, 09:44:12 pm »
Thanks for the help I'm painting with acrylic with my bad eye sight and probably two weeks of rain it should turn out fine  ;D jimson
