Author Topic: Husky WR250 Problem, help needed :- Not VMX  (Read 9508 times)
« on: August 28, 2009, 08:16:46 pm »
this ones for a mate.
he has a 2002 Husky WR250 that is fouling plugs on trail rides. its fine when the tracks are open and flowing, but as soon as it gets tight and twisty and you can't open the throttle up it fouls plugs after about 20mins. plugs are wet and oily.  bike runs strong when reved doesn't miss at all and does not blow any smoke. oil ratio is 40:1 Motorex, its been happening on the last 4 rides so cannot be dodgy fuel as fuel was fresh each time.
what he has checked.
carb all ok.
air leaks from magneto side ok. would appear not to be a gearbox side main seal as it does not blow smoke and pulls hard when reved.
reeds ok
no coolant leaks
what we assume its not
electrics as its very easy to start, runs well and will pull 140Kmh in top gear (surely that a good sign of healthy electrics)
piston/bore, as had a rebuilt top and bottom end about 6 rides ago, no problem till recently
Any clues guys?
« Last Edit: August 28, 2009, 08:26:44 pm by Hoony »
All Things 414
Re: Husky WR250 Problem, help needed :- Not VMX
« Reply #1 on: August 28, 2009, 08:20:37 pm »
Has the bike just started doing this or has he just aquired it Hoony (the bike that is)?
« Reply #2 on: August 28, 2009, 08:24:26 pm »
He has had the bike since new in 2002 RossMeister, only just started doing this.
that will teach him to buy a Hucking Pusky  :D
All Things 414
« Reply #3 on: August 28, 2009, 08:30:33 pm »
Is it running ok down low and then fouling or running like the total true puss bucket that it is and then fouling?  :-\
« Reply #4 on: August 28, 2009, 08:46:57 pm »
A too cold a plug, drop to an 8 heat range if he's running a 9.
« Reply #5 on: August 28, 2009, 08:51:37 pm »
 its running good down low and fouls after time, when you get to a area when you can open it up like a fire break or road and give it the berries it does not clear and will foul.
« Reply #6 on: August 28, 2009, 08:53:25 pm »
standard heat range is 9 i think,  he ran out of spare plugs when i was with him and we used a new 8 from my spare for the KTM, it fouled after time as well.
All Things 414
« Reply #7 on: August 28, 2009, 09:17:20 pm »
Are you sure everything is ok in the carb?
« Reply #8 on: August 28, 2009, 09:31:03 pm »
Nice bikes, v high strung.
change the engine seals and put a kit through the carb and check/change any induction rubber parts.
 Do  plug chop, i think its sucking air
Offline holeshot buddy
  • sunshine coast qld
« Reply #9 on: August 28, 2009, 10:49:02 pm »
it will be the ignition for sure
common on 250s and 360s
usuall first sign is fouling plugs
stator faulty
forget about how it has spark and starts
that will be the problemo ;)
follow me to first turn
« Reply #10 on: August 29, 2009, 11:27:05 am »
G'day Russell,
how can you be so sure about the ignition, is it a common fault with huskies or have you had a similar problem on other bikes?
is it a weak spark at low revs problem and stator insulation breaking down?
« Reply #11 on: August 30, 2009, 10:27:49 pm »
thats exactly what it is and i have struck this
on 250 and 360 huskys
pull of the stator flywheel cdi and coil
send it all to bert at rewinds in vicco
he can test the whole system for a good price
then fix it if it is needed ;)
« Reply #12 on: August 30, 2009, 10:40:36 pm »
This is quite similar to the way my WR360 died. Sometimes it would run like a rocket, other times it would just flame-out for no apparent reason.
Always started easily, up until it really dropped its guts...
EVERYONE said "Yep, its the stator" when I told them the symptoms.
« Reply #13 on: August 31, 2009, 08:58:11 am »
Good luck sending it to Bert at Small Coil Rewinds :o. Hopefully he'll get it right, hopefully......
« Reply #14 on: August 31, 2009, 06:49:44 pm »
i used to use  jack at city auto electrics in coburg
he was very good but he has got a bit expensive
charged me $400
to rewind a canam stator ::)
who do you use michael
cheers rusty ;D
