Author Topic: MX 250B Forks - Oil Refill 'Amt (per leg)?  (Read 2972 times)
Offline BJJ
    • Remote PC
« on: August 16, 2009, 02:01:04 pm »
Would someone be so kind to post the Millilitres for the above model Yamaha.  Cheers,
Re: MX 250B Forks - Oil Refill 'Amt (per leg)?
« Reply #1 on: August 16, 2009, 03:23:12 pm »
cam
take the spring out depress the fork and fill to 150mm befor the top and it should be about right,just need to get the grade of oil right
jim
Motoman
« Reply #2 on: August 20, 2009, 01:16:18 pm »
Jim
While you are at it, can you help with what oil to I use in the shocks of my MX250A? They are going off to be serviced this summer but in the mean time I plan to keep the oil topped up until full service is done.
thanks
« Reply #3 on: August 20, 2009, 02:01:35 pm »
194cc for the 250,360 and 500mx
Motoman
« Reply #5 on: August 20, 2009, 03:57:18 pm »
Thank you for your expertise......"seek and ye shall find"!
« Reply #6 on: August 21, 2009, 03:37:39 pm »
BJJ - which info do you want ?   got the manual, the parts books and the spce sheets and the spec sheets for the spce sheet upgrades
Offline BJJ
    • Remote PC
« Reply #7 on: August 24, 2009, 08:34:42 pm »
If you have time to scan?,  or I will happily pay for a couple of photocopies or a fax.  Particularly,  I do not know a lot about suspension and if I would spend some money this year,  it would be suspension,  then a little on the transmission.  All related help very appreciated.
