Author Topic: YZ250F 1979 Rear drum floating Backing plate Bush?  (Read 2191 times)
Offline oldyzman
  • 250 two stroke!
« on: August 02, 2009, 09:37:20 pm »
Gday All, Can someone tell me if the stel bush in the backing plate is suposed to move freely in the magnesium backing plate. As the one on my F makes the rear suspension really stiff when the rear axle is tightened up.. If I reamove the rod that runs to the frame from the backing plate it then frees up the suspension.
Cheers Brett
Re: YZ250F 1979 Rear drum floating Backing plate Bush?
« Reply #1 on: August 02, 2009, 10:03:12 pm »
Yes, they should rotate freely - that's the whole point of the bush being there.
On the plus side, it looks like you've avoided the typical flogged-out backing plate drama...
Offline oldyzman
  • 250 two stroke!
« Reply #2 on: August 03, 2009, 12:28:07 am »
Thanks Nathan,  always a positive spin isn't there... Will try to unseize it...
Cheers Mate...
