Author Topic: won't start when its hot  (Read 2655 times)
zman
« on: July 11, 2009, 06:26:11 pm »
g day all just wondering if someone could give me an idear on why my 82 rm250 won't start off the kick starter when its hot. when its cold its starts easy and runs perfect. but when its hot i have to push start it . its got the standard carb on it with 300 main & 60 pilot
thanks cheers :)
Offline matcho mick
    • Moto Tumbi
Re: won't start when its hot
« Reply #1 on: July 12, 2009, 12:46:08 am »
float level too high?,symptoms sounds tad rich,usually helps cold starts,but too "fuelly" when hot,try lean out the idle mixture air/fuel screw?,hth :P
lms6201
« Reply #2 on: July 12, 2009, 08:52:58 am »
how worn is it ?
zman
« Reply #3 on: July 12, 2009, 09:34:59 am »
the motor is good it was rebuilt not long before i bought the bike. could it be the low speed stator coil or the plug coil. how do i measure where the float level has to be
« Last Edit: July 12, 2009, 10:13:27 am by LWC82PE »
Offline holeshot buddy
  • sunshine coast qld
« Reply #5 on: July 12, 2009, 09:15:09 pm »
check the readings out of the stator
sounds like it could be a low speed coil
common on this model ;)
follow me to first turn
