Suzuki
won't start when its hot
Topic: won't start when its hot (Read 2657 times)
zman
July 11, 2009, 06:26:11 pm »
g day all just wondering if someone could give me an idear on why my 82 rm250 won't start off the kick starter when its hot. when its cold its starts easy and runs perfect. but when its hot i have to push start it . its got the standard carb on it with 300 main & 60 pilot
thanks cheers
matcho mick
Re: won't start when its hot
July 12, 2009, 12:46:08 am »
float level too high?,symptoms sounds tad rich,usually helps cold starts,but too "fuelly" when hot,try lean out the idle mixture air/fuel screw?,hth
lms6201
July 12, 2009, 08:52:58 am »
how worn is it ?
zman
July 12, 2009, 09:34:59 am »
the motor is good it was rebuilt not long before i bought the bike. could it be the low speed stator coil or the plug coil. how do i measure where the float level has to be
LWC82PE
Superstar
July 12, 2009, 10:11:02 am »
this would be handy. it will tell you the float level and how to measure it
http://cgi.ebay.com/ebaymotors/Suzuki-RM-125-250-465-500-Service-Manual-1981-1988_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1205Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem5881fdfc0eQQitemZ380138028046QQptZMotorsQ5fManualsQ5fLiterature
Last Edit: July 12, 2009, 10:13:27 am by LWC82PE
holeshot buddy
sunshine coast qld
July 12, 2009, 09:15:09 pm »
check the readings out of the stator
sounds like it could be a low speed coil
common on this model
follow me to first turn
Suzuki
