Author Topic: 1983 RM250D Carbie settings  (Read 3718 times)
Offline Tossa
« on: July 03, 2009, 10:08:56 am »
Jusr bought the bike, looked in the Clymers Manual and only shows a round slide carbie settings, when it should be a Flat slide.
Carbie No VM38
Jet neeedle 6FJ41
Main jet 290
Pilot jet 60
Needle Jet Q-8
Throttle cut away 4.0
spigot size 43mm
Bell 62mm
Body length 116mm
Does this sound right
Barry
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: 1983 RM250D Carbie settings
« Reply #1 on: July 03, 2009, 10:26:34 am »
Details I have is...
VM38
Needle jet     6FJ40-2
Jet, needle    Q-6
Throttle slide 4.0
Pilot jet        60
Main jet        310
Ban BLACK rims NOW
CamP
« Reply #2 on: July 03, 2009, 12:32:38 pm »
Not sure about the '83 but the stock '82 jetting for US bikes is:
300 Main Jet
2.5 Air Jet
4FJ40-2 Jet Needle
Q-6 Needle Jet
4.0 Slide Cut-away
60 Pilot Jet
1.4 By-pass
0.6 Pilot outlet
1.5 Air screw
3.3 Valve seat
100 Starter jet
RMJJ
« Reply #3 on: July 03, 2009, 06:38:37 pm »
stock USA 83 D settings are
VM38SS flat slide
main               300
needle jet        Q-6
Jet needle        4fj40-2
pilot                 60
slide                 4
« Last Edit: July 03, 2009, 06:40:08 pm by RMJJ »
Offline Tossa
« Reply #4 on: July 04, 2009, 10:48:13 am »
thanks fella's isn't it amazing the variances that everybody has, depending on where you get the info
Barry
Offline Tossa
« Reply #5 on: July 06, 2009, 01:18:06 pm »
now there is only one problem and that is a VM is the round slide and TM is the flat carbie which is what the RM came with
CamP
« Reply #6 on: July 06, 2009, 02:22:05 pm »
The 83 RM250 carb is definitely TM38. I have a 83 RM250 carb in my attic if you'd like me to pull it apart and check the jetting for you.
Offline Tossa
« Reply #7 on: July 06, 2009, 02:23:33 pm »
No, you are right and have sent those settings to Hatricks for the carbie, thanks for your help
Barry
