Author Topic: Sprite-UK/American Eagle-USA /Alron-AUST  (Read 692260 times)
Re: Sprite-UK/American Eagle-USA /Alron-AUST
« Reply #750 on: May 26, 2012, 12:23:35 am »
there's no way it's pre 65 legal.
Due to tank,sideplates and plastic mudguards ?
cheers A
« Reply #751 on: May 26, 2012, 12:04:25 pm »
I had another look and it's legal Alison. Frank's a bit sketchy about when they first Starmaker motor in the Sprite which gave me doubts. All good now.
Offline GD66
« Reply #752 on: May 26, 2012, 12:35:59 pm »
Still looks a bit too well-endowed in the rear shock travel dept, all the same...
« Reply #753 on: May 26, 2012, 02:42:13 pm »
Dave well the motor is DT1 but the frame is not Yamaha from any that Ive seen . the triple clamps look Bultaco ish . front hub looks Dt1 . more photos please Dave
« Last Edit: May 26, 2012, 02:44:09 pm by iainyz »
« Reply #754 on: May 26, 2012, 02:46:46 pm »
Belay that about hubs, brake stay rules out DT1 .
Re: Sprite/Alron/American Eagle
« Reply #755 on: May 26, 2012, 03:13:45 pm »
Made in Birmingham UK Dave and yes its a Sprite kit frame ~Well done  :P
Last count from JC ~ Jan 2010
2 400 restored
2 400 rollers
1 400 missing lots of bits
TOTAL 5
3 250 OSSA complete
The blue bike is a 250 ossa that hasn't been found
May have to up date this list VMX60  ;D
« Reply #756 on: May 26, 2012, 03:56:43 pm »
Dave, you've got an early 'pre fastback' Sprite/American Eagle frame with a DT1 Yamaha motor. I hate to spoil your excitement but the forks aren't Ceriani's, they're either REH or more likely Sprite forks which were a cheap knock off of REH. The best way of knowing is by pulling the triple clamps off the bike and seeing if they have a proper head stem (REH) or a bit of threaded rod (Sprite).The front hub is REH or possibly some Italian thing or other.
The Yamaha motor is a vast improvement on the Sprite engine that probably lived in there and probably better than the Villiers Starmaker too ;D. The problem with this engine swap is that the Sprite frame is a real heavyweight, much heavier than the DT1 frame, much like when I fitted an XL Honda motor into a Montesa King Scorpion lardmaster, way heavier than the original XL unit.
 I hope you didn'y pay too much mate ::)
« Last Edit: May 26, 2012, 03:59:31 pm by firko »
Offline VMX60
« Reply #757 on: May 26, 2012, 05:07:08 pm »
Terrific pickup Dave
The roller looks like it is all early Sprite even the DT motor is pre reed model
The pipe looks to me a cut up Montesa model   :-\
Im jealous as hell finding that Treasure  :)
Offline VMX60
« Reply #758 on: May 26, 2012, 05:33:21 pm »
Dave
This would have to be close to the frame kit    ;D
Offline pancho
« Reply #759 on: May 26, 2012, 06:16:14 pm »
 I'm confused,  Didn't DT1s have the 'enduro' twin plug head like the RT1?
pancho.
Offline VMX60
« Reply #760 on: May 26, 2012, 06:39:44 pm »
Dave
The photo of the Sprite is label 1967
The DT1 had a blank plug next to the s/plug hole side by side    :-\
« Reply #761 on: May 26, 2012, 07:54:03 pm »
Dave I think you will find the DT1 head is a later than 70 head as all the stock heads had twin plugs .
Iain
« Reply #762 on: May 26, 2012, 11:24:38 pm »
The engine/head all seems to be original piston port DT1 stuff. The more I look at the bike the more I like it Dave. I've got the exact same roller under the house which will eventually recieve a 360 Maico square barrel engine to build a replica of the '68 Sprite Maico raced by Terry Chalinor in the day. Frank Hipkin's given me the specs and encouragement to build it but it's about 5 down the current production line. The front hub has me bamboozled though. I thought they used a conical hub originally but Franks kit photo submitted by VMX60 shows it with a full width so what would I know??? ::)
Offline VMX60
« Reply #763 on: May 27, 2012, 12:00:08 am »
Firko
Maybe its a very early GYT  Yamaha kit top end single plug and that long inlet block to give a bit of pulling power
Wow might even have a chrome bore with the one ring piston Rare as ;D
Still love to have that in my shed
Offline JC
« Reply #764 on: May 27, 2012, 09:18:49 am »
Excellent find Dave. I've often tho't - why doesn't somebody put a Yam engine in one of these Sprite frames?
