Author Topic: Sprite-UK/American Eagle-USA /Alron-AUST  (Read 734975 times)
Offline JC
Re: Sprite/Alron/American Eagle
« Reply #660 on: January 31, 2011, 09:43:22 am »
I'll take the MZ in the background
You did get me thinkin  ;D and I found a full photo of her (MX 69 ISDT) !! Should be a "he", cause it looks like a right work horse too. ;)  8) Have you got any history on them JC.? cheers A
No Alison. (I wish)  I hated them back in the day. Regarded them as old-fashioned outdated heavyweight iron-curtain slugs, but have come to appreciate them more recently - at least the circa73 & later models.
« Reply #661 on: January 31, 2011, 10:48:31 am »
Here ya go Alison.
« Last Edit: January 31, 2011, 11:19:54 am by firko »
« Reply #662 on: January 31, 2011, 11:07:10 am »
Frank Hipkin sent these and the above clippings. I've been meaning to put them up for a couple of weeks. Note the comment by Frank regarding Husky reneging on their deal behind his back.
« Last Edit: January 31, 2011, 11:09:43 am by firko »
« Reply #663 on: February 01, 2011, 01:39:14 pm »
Thanks Firko,all good.
Some how we have that bit of info from an old magazine.Just in a different format.
cheers Alison
« Last Edit: February 01, 2011, 01:43:36 pm by VMX247 »
Offline 223
« Reply #664 on: February 01, 2011, 07:21:13 pm »
<a href="http://tinypic.com?ref=24l2ded" target="_blank"><img src="http://i54.tinypic.com/24l2ded.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com?ref=6jovox" target="_blank"><img src="http://i52.tinypic.com/6jovox.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
ciao Graziano
« Reply #665 on: February 02, 2011, 10:25:07 am »
Thanks and total gratitude goes to Dan Vitaletti in the USA for his over whelming help.Also to Marks Vintage Swapmeet.
They have arrived !!!  ;D
« Last Edit: February 02, 2011, 10:27:49 am by VMX247 »
« Reply #666 on: February 04, 2011, 11:19:29 pm »
Hi JC,hope all is well up on the home range with the rain and wind.!!
Found a 1976 piece on the MZ  in vmx mag #28 pg 35  8)
« Reply #667 on: February 13, 2011, 11:35:53 pm »
Sprite at ths UK Stafford classic bike show 18/10/10
Amazing classic shows in the UK...if your heading that way  ;D  Did you go over VMX60 and if so is there anymore pics  :P  ;D  ??
http://www.classicbikeshows.com/
http://ausvmx.ning.com/photo/photo/listForContributor?screenName=2w1xa26p2gdvn&xg_source=activity
Shit there was some gear at this show..c&j/yammie real sweet,ksi,Greeves you name it money/bling dripping everywhere  :P
« Last Edit: February 14, 2011, 12:07:33 pm by VMX247 »
Offline mike1948
  • Margate, QLD
« Reply #668 on: February 14, 2011, 05:58:31 pm »
I'll be over there for the classic show at Easter, hope to pick up some good engine parts for my pre60 HJH.
Mike
« Reply #669 on: March 04, 2011, 10:24:10 pm »
Now here's one groovy American Eagle. This thing's a rolling time capsule with it's hot rod paint, snail pipe, Skunk inlet and Curnutts.....I love it. ;D
1970 American Eagle with F81M greenstreak motor. Very trick skunk works intake,
beautiful snail pipe, curnutts again, zokes in the front. Not vintage legal
travel right now. $1200
Offline JC
« Reply #670 on: March 05, 2011, 09:11:29 am »
Now there's an idea for yr F81M engine Mark. With 7/4" travel, it'd (nearly) be competitive.
Love the Skunk-style inlet manifold. Thats what those engines need. But don't go much for the snail pipe that protrudes down below the frame tho.
« Reply #671 on: March 05, 2011, 10:03:24 am »
Agreed John. The only thing preventing the F81 American Eagle being competitive is the weight of the frame. These things are damn heavy....twice the weight of the equivalent sized Hindall, indicating the truth of the frame being twice the wall thickness and mild steel rather than chro-mo. I'd be pretty certain that the stock Kawa frame would also be much lighter. I've got two frames, one (the better one) is definitely getting a 360 square barrel Maico engine to produce a Challinor Replica Maico/Sprite....the other frame's pretty sad, someone had fitted a Triumph 500 to it using angle iron engine mounts and a stick welder. Maybe one day I'll get to it....... ;)
The above bike had had some serious work done to it by someone who knew what he was doing. The LTR conversion appears to be well executed, the Skunk Works inlet was the hot ticket item for Kawa rotaries back in the day, and the Curnutt shocks and Marzocci (I think) forks are a definite 1975 era plus on the original stuff. The snail pipe Supertrapp muffler hanging below the frame rail can be easily fixed. The pipe seems to be similar to the snail pipe I had on my VR Monty back in the day...I can't remember the brand for the life of me (Maybe it was also made by Skunk Works ). The paint job is so early 70's it reignites my taste lapse genes :o. I had a similar Rick Pacey paint job on my Lobito. ;D
Offline shorelinemc
  • life sucks&then you die
« Reply #672 on: March 05, 2011, 12:58:32 pm »
this one is in washington state, near my mate if any one wants it
« Reply #673 on: March 09, 2011, 11:56:15 pm »
WWOOOOOHHHHOOOO She runs-real quiet 2 stroker too "GO the mighty Villiers" ;D He found the problem of cluth slipping while kicking it over,opened it up and it was full of automatic transmission fluid.  :(
Experenced in the past ATF causing clutch slipping best to use plain mc engine oil in primary cover..anyone else had this problem ??
cheers A
« Reply #674 on: March 10, 2011, 07:52:33 am »
cheers A
          8)
