Author Topic: Rm 250 T axle LHS spacer Rear  (Read 5274 times)
« on: May 22, 2009, 07:28:47 pm »
Shit happens ??? picked up my items from platter this sarvo and the above item is missing  ???
Can someone supply me with the dimensions So I can  get one turned up .     LHS axle spacer Rear
I've knocked the centre out of an old bearing    6202 which is close ( 10mm long ) AS AN INTERIM
« Last Edit: May 24, 2009, 07:14:21 pm by oldfart »
Re: Rm 250 T axle LHS spacer Rear
« Reply #1 on: May 25, 2009, 07:07:00 pm »
Ok I'll try a different approach, Does anyone want to sell me a Rear axle assembly For a Rm 250 T .
Offline pmc57
« Reply #2 on: May 25, 2009, 09:07:32 pm »
So length is about 10mm, what's the OD, ID and any other features? I can have a look in my box of goodies to see what I've got.
Tornado
« Reply #3 on: May 25, 2009, 09:15:48 pm »
will measure mine tomorrow if you can wait
« Reply #4 on: May 25, 2009, 09:28:42 pm »
part   # 19
Tornado
« Reply #5 on: May 25, 2009, 09:45:19 pm »
7 pm tomorrow night  and ps thanks for the parts fiche-makes things a whole lot less confusing
Tornado
« Reply #6 on: May 26, 2009, 08:38:26 pm »
Well picked up my verniers and they are digital but with a flat battery they are only good for measuring oranges for an orange gun. there is no fine markings on the shaft to be accurate. will get another battery tomorrow and measure tomorrow night.
sorry
Offline pmc57
« Reply #7 on: May 26, 2009, 08:44:04 pm »
Nothing in my box of goodies, sorry
« Reply #8 on: May 26, 2009, 08:52:53 pm »
Thanks for looking      Pete
Offline suzuki27
« Reply #9 on: May 28, 2009, 05:48:19 pm »
How did you go ?. I can measure mine on the w/end and report back if still needed.The LHS has a small raised section on the side that points towards the wheel bearing-this slightly wider section does not extend all the way to the perimeter of the spacer...from memory.
« Reply #10 on: May 28, 2009, 05:55:59 pm »
THATS THE ONE ....memory tells me it abuts bearing small face, then has a step up with clearance around hub.
If you could measure that would be much appreciated
Offline suzuki27
« Reply #11 on: May 28, 2009, 06:54:36 pm »
Yep. I will get it done this w/end.
Tornado
« Reply #12 on: May 28, 2009, 07:00:52 pm »
so the pics I emailed helped? or made it worse?
« Reply #13 on: May 28, 2009, 09:03:23 pm »
Tex, pics Helped thanks :) . Measurements is what I needed
DR
« Reply #14 on: May 28, 2009, 09:30:42 pm »
excuses excuses...ya fussy ol' bastard oldfart! ::) so the new zinc plating didn't match the offcut of galv waterpipe spacer you were using and now you want to make a replacement from some exotic zinc plated substance ::) blaming the platers..as if they'd lose anything like that!! ;D
