Author Topic: Rm 250 T axle LHS spacer Rear  (Read 5275 times)
Re: Rm 250 T axle LHS spacer Rear
« Reply #15 on: May 29, 2009, 04:02:31 pm »
wish it was that easy Chris,  A lathe is my next purchase
Guest what ....It's piissing with rain again as I punch away at key board  ::)
Remember this pic from last year
DR
« Reply #16 on: May 29, 2009, 04:07:40 pm »
 :D sure I remember young fella, I was praising the heavens for the little shower and a wee puddle it left....right at the bloody entrance!! ::) no rain here at this momnet but I guessed from the look of the sky someone would be getting it ;)
Offline suzuki27
« Reply #17 on: May 30, 2009, 05:45:09 pm »
The measurements for the LHS spacer are: the narrow part towards the outside of the spacer is 9.7mm. I got readings of 9.6 to 9.8 mm, so 9.7mm is good. Now, the raised section that faces the wheel bearing is 10.7mm. So that wider section is 1mm wider. ID is 15mm and OD is 34mm.  The RHS spacer is 7mm wide with same ID & OD. Cheers.
« Reply #18 on: May 30, 2009, 07:28:46 pm »
THANK VERY MUCH  :)   I'll get them turned up on monday
« Reply #19 on: May 30, 2009, 10:30:20 pm »
Is that right ??? Are you walking on that water Doc or is it some optical illusion? I wondered how wet it was up there.
Stew have a look at a HQ500M from Minitech in Brisbane, has long and cross power feeds and a great big table,mine was $2600 delivered.
DR
« Reply #20 on: May 31, 2009, 06:35:03 am »
optical illusion Loz, I was only at the edge as the water. The entrance just past the armco was not navigational by car, 4wd or foot until later that day ;)
