Husqvarna
Electronic Ignition - PVL or MZB - Husky 500XC
Topic: Electronic Ignition - PVL or MZB - Husky 500XC (Read 4758 times)
subarumy98
C-Grade
April 05, 2009, 07:50:33 am »
HI
All fingers point to the ignition that can't keep up - so what is the suggestion; PVL or MZB.
Any words of wisdom or guidance from those in the know...
T
Last Edit: April 05, 2009, 04:45:14 pm by subarumy98
albrid-3
Re: Electronic Ignition - PVL or MZB - Husky 500XC
April 05, 2009, 08:49:22 am »
l am also thinking about buying a PVL Ignition, my friend runs PVL on this BSA B50, Works Great. My choice for you PVL.
CHEERS
JohnnyO
Qld
April 05, 2009, 09:04:18 am »
I can recommend the PVL. I have one on a 490 maico and it's been faultless. I know nothing about a MZB.
PEZBerq
Brisbane
April 06, 2009, 08:34:36 pm »
New ignitions are expensive.
I would ask Steve at Betta Bikes in SA to take a look at it first. I had my 430 XC Motoplat Mini 6 ignition stator repaired for about $250 all up if I recall. Got mine sorted great
Helps if the wires out the back of the stator are in good shape - insulation good and not frayed and hanging on by a few strands! If wires dodgey it is a gamble - you can repair the stator but have the wires snap off
Otherwise PVL seems the go except if you want lights then the MZB is the go.
LWC82PE
Superstar
April 06, 2009, 08:55:42 pm »
i have used MZB on other bikes. good quality, well built, easy to install, reliable and good value
subarumy98
C-Grade
April 20, 2009, 01:19:38 am »
Hold thumbs...
MZB on its way - will advise.
Husqvarna
