Author Topic: Electronic Ignition - PVL or MZB - Husky 500XC  (Read 4763 times)
Offline subarumy98
« on: April 05, 2009, 07:50:33 am »
HI
All fingers point to the ignition that can't keep up - so what is the suggestion; PVL or MZB.
Any words of wisdom or guidance from those in the know...
T
« Last Edit: April 05, 2009, 04:45:14 pm by subarumy98 »
albrid-3
Re: Electronic Ignition - PVL or MZB - Husky 500XC
« Reply #1 on: April 05, 2009, 08:49:22 am »
l am also thinking about buying a PVL Ignition, my friend runs PVL on this BSA B50, Works Great. My choice for you PVL.
CHEERS
« Reply #2 on: April 05, 2009, 09:04:18 am »
I can recommend the PVL. I have one on a 490 maico and it's been faultless. I know nothing about a MZB.
Offline PEZBerq
  • Brisbane
« Reply #3 on: April 06, 2009, 08:34:36 pm »
New ignitions are expensive. :o :o :o  I would ask Steve at Betta Bikes in SA to take a look at it first.  I had my 430 XC Motoplat Mini 6 ignition stator repaired for about $250 all up if I recall.  Got mine sorted great :) :) :) Helps if the wires out the back of the stator are in good shape - insulation good and not frayed and hanging on by a few strands!  If wires dodgey it is a gamble - you can repair the stator but have the wires snap off  >:( >:(
Otherwise PVL seems the go except if you want lights then the MZB is the go.
« Reply #4 on: April 06, 2009, 08:55:42 pm »
i have used MZB on other bikes. good quality, well built, easy to install, reliable and good value
Offline subarumy98
« Reply #5 on: April 20, 2009, 01:19:38 am »
Hold thumbs...
MZB on its way - will advise.
