Author Topic: Eligilibty scrutineer at the Nationals  (Read 118600 times)
Re: Eligilibty scrutineer at the Nationals
« Reply #180 on: April 08, 2009, 03:26:52 pm »
18 Classic Motocross & Dirt Track
18.3.0.1 Methanol is permitted
why doesn't it have that in the index (fuel) in the front like the rest of the disciplines   :(
saving paper  :-\
cheers Alison
Old Husky
« Reply #181 on: April 09, 2009, 06:44:17 pm »
I have a question re eligilibty, what are the restrictions on Pre 65 carbies, are roundslide Mikunis legal, this a genuine question, I am building up a 67 Husky 250 and do not have a carby for it, a Mikuni would be a good choice.
« Reply #182 on: April 09, 2009, 06:51:08 pm »
carbies were discussed a few pages back in this topic. have a read back through the pages and see if you find the answer you need there.
dirtrumpy
« Reply #183 on: May 14, 2009, 10:31:27 am »
The Pre 65 class - A matchless running internal ignition, will it need to have a dummy magneto to restore external appearance?
« Reply #184 on: May 14, 2009, 02:47:48 pm »
I found on page 158 of the MA bible-
rule 18.6.0.1 Engines must remain externally unchanged.
rule 18.6.0.5 Ignition:Any ignition system can be used as long as the external appearance of the engine remains unchanged..
hope this helps ?
« Reply #185 on: May 14, 2009, 03:39:20 pm »
No. You'll be right.
« Reply #186 on: May 14, 2009, 03:47:16 pm »
its not even August , and the rulebook people are in full swing already
love you too Walter, :-*  sorry for helping a fellow bike enthusiast out.
cheers Alison
Mark Austin
« Reply #187 on: May 14, 2009, 06:38:00 pm »
MIKUNI CARBURETTORS
Hi lads,
I know this has been mentioned before, but I'm still in the dark...
For the national classic titles in 2009.
Can I run a round slide Mikuni carby in the Pre 65 class
Can I run a flat slide Mikuni in the Pre 78 Open class.
Both these bikes are set up with these carbies now and are running perfectly.
Do I have to change both of them to be eligible for both classes.
I'm willing to change them if I have to - I just want a definitive answer.
Mark
« Last Edit: May 14, 2009, 06:41:51 pm by auscobul »
« Reply #188 on: May 14, 2009, 07:11:19 pm »
I wouldn't think you could run a flat slide Mikuni in pre '78 or even evo as they weren't on production bikes til around '82.
Offline mboddy
  • Canberra
« Reply #189 on: May 14, 2009, 07:19:36 pm »
So what carbies can be used?
This is a list of some common carbies and their availability date:
Lectron (non powerjet) 1976
Lectron powerjet 1979
Mikuni powerjet (roundslide) 1979
Mikuni TM 1982
Keihin PJ 1985
Mikuni TMX 1987
Keihin PWK 1988
Mikuni TMS 1992
Mikuni PM 1998
Keihin PWM 1999
Therefore as the flatslide Mikuni was not available in 1977 it cannot be used in Pre-78.
Vinduro Penrite Team
colmoody
« Reply #190 on: May 14, 2009, 08:07:59 pm »
Mboddy, that list of carburetor elegibility you just quoted. It kinda looks official. If so can it be viewed anywhere.
Taa
Offline mboddy
  • Canberra
« Reply #191 on: May 14, 2009, 08:22:04 pm »
I did a lot of eligibility research when I was the PCRA New Era eligibility guy.
This list is just what I found out.
211kawasaki
« Reply #192 on: May 17, 2009, 06:36:06 pm »
The carb question will be as so.
Pre 78 and older will not be able to use a flat slide
EVO, and Pre 85 will be able to use a flat slide of any type.
211
211kawasaki
« Reply #193 on: May 17, 2009, 06:38:21 pm »
Guys
the minutes of the Commission should be with your state LCBs
Can I suggest if your interested your club gets a copy and responds through their state committee as soon as possible.
I will be available to discuss any aspect of the proposals at CD6 if you want just find 211 and the KK Kompound.
211
Offline mboddy
  • Canberra
« Reply #194 on: May 17, 2009, 09:55:08 pm »
Why not?
