Author Topic: ts185 forks and /or clamps , good $35  (Read 5187 times)
lms6201
« on: February 26, 2009, 08:36:57 am »
0412708957
Offline JC
Re: ts185 forks and /or clamps , good $35
« Reply #1 on: February 26, 2009, 11:33:23 am »
What year/model?
lms6201
« Reply #2 on: February 26, 2009, 12:45:23 pm »
ts185 er
lms6201
« Reply #3 on: February 26, 2009, 05:41:52 pm »
jc , which ts forks were u wanting ?
« Reply #4 on: February 26, 2009, 07:35:22 pm »
They'd be leading axle correct? No good for pre75
« Reply #5 on: February 26, 2009, 07:57:33 pm »
TS185ER 79 onwards - leading axle, 33mm
lms6201
« Reply #6 on: February 27, 2009, 05:58:45 am »
yep leading axel , circlip spring retainers
Doc
« Reply #7 on: February 27, 2009, 08:32:13 am »
out of interest, the only pre'75 Suzuki model with the leading axle forks are the RL250 ;)
« Reply #8 on: February 27, 2009, 08:47:28 am »
c-clip spring retainers ??? my forks dont have these? fork caps are screw in and the only c-clips on the forks are ones that hold in the seals
Offline JC
« Reply #9 on: February 27, 2009, 04:33:22 pm »
Ims,
I could do w a set of the triple clamps for the 33mm leading axle ER forks.
And a front brake plate too
Doc
« Reply #10 on: February 27, 2009, 06:11:41 pm »
I probably have a set of TS185ER clamps kicking around JC. Will have a look and let you know ;)
Ims the forks you have there are either TS100ER or TS125ER (185's as Leith said have the screw in caps with a 1/2 drive slot) I'll buy the 100/125 forks from you if the chrome is good and if no-one else has first dibs ;)
« Last Edit: February 27, 2009, 06:21:31 pm by Doc »
Doc
« Reply #11 on: February 27, 2009, 06:43:10 pm »
JC, just checked, I do have a pair of 185 clamps I'm not using in the foreseeable future ;)
lms6201
« Reply #12 on: February 27, 2009, 09:04:29 pm »
doc , i just got them out and checked the caps , they screw in inside the fork ( sorry they looked like circlips in the dark shed ) they have a square recess like a 1/2" socket for removal  33mm dia
Doc
« Reply #13 on: February 27, 2009, 09:14:29 pm »
that be the 185 suckers alright. With the rubber caps fitted one could assume they be circlip type ;) no problemo..
Offline JC
« Reply #14 on: February 28, 2009, 10:44:31 am »
Doc,
I'll take the 185ER triples if you don't need them.
(I've still got the RM100 engine for you)
