Marketplace
For Sale
ts185 forks and /or clamps , good $35
All
Topic: ts185 forks and /or clamps , good $35 (Read 4852 times)
lms6201
February 26, 2009, 08:36:57 am »
0412708957
JC
Re: ts185 forks and /or clamps , good $35
February 26, 2009, 11:33:23 am »
What year/model?
lms6201
February 26, 2009, 12:45:23 pm »
ts185 er
lms6201
February 26, 2009, 05:41:52 pm »
jc , which ts forks were u wanting ?
pokey
February 26, 2009, 07:35:22 pm »
They'd be leading axle correct? No good for pre75
LWC82PE
Superstar
February 26, 2009, 07:57:33 pm »
TS185ER 79 onwards - leading axle, 33mm
lms6201
February 27, 2009, 05:58:45 am »
yep leading axel , circlip spring retainers
Doc
Reply #7 on:
February 27, 2009, 08:32:13 am »
out of interest, the only pre'75 Suzuki model with the leading axle forks are the RL250
LWC82PE
Superstar
Reply #8 on:
February 27, 2009, 08:47:28 am »
c-clip spring retainers
my forks dont have these? fork caps are screw in and the only c-clips on the forks are ones that hold in the seals
JC
Reply #9 on:
February 27, 2009, 04:33:22 pm »
Ims,
I could do w a set of the triple clamps for the 33mm leading axle ER forks.
And a front brake plate too
Doc
Reply #10 on:
February 27, 2009, 06:11:41 pm »
I probably have a set of TS185ER clamps kicking around JC. Will have a look and let you know
Ims the forks you have there are either TS100ER or TS125ER (185's as Leith said have the screw in caps with a 1/2 drive slot) I'll buy the 100/125 forks from you if the chrome is good and if no-one else has first dibs
Last Edit: February 27, 2009, 06:21:31 pm by Doc
Doc
Reply #11 on:
February 27, 2009, 06:43:10 pm »
JC, just checked, I do have a pair of 185 clamps I'm not using in the foreseeable future
lms6201
Reply #12 on:
February 27, 2009, 09:04:29 pm »
doc , i just got them out and checked the caps , they screw in inside the fork ( sorry they looked like circlips in the dark shed ) they have a square recess like a 1/2" socket for removal 33mm dia
Doc
Reply #13 on:
February 27, 2009, 09:14:29 pm »
that be the 185 suckers alright. With the rubber caps fitted one could assume they be circlip type
no problemo..
JC
Reply #14 on:
February 28, 2009, 10:44:31 am »
Doc,
I'll take the 185ER triples if you don't need them.
(I've still got the RM100 engine for you)
All
Marketplace
For Sale
