Author Topic: ISO :- early 80's YZM500 pic's  (Read 18760 times)
Re: ISO :- early 80's YZM500 pic's
« Reply #15 on: September 19, 2007, 07:55:23 pm »
I have the poster you are talking about somewhere down in the garage , YZM500 aircooled powervalved , will try to find it
 any luck with finding this ?
« Reply #16 on: September 19, 2007, 07:56:08 pm »
found it...dont ask me what issue it is cause the covers been ripped off so i will give you a few details on what adb says about it before i try and have a go at scanning it for you all....so here goes.....leif perssons works yzm500 yamaha.the engine is still aircooled but is more than a match for the water pumpers in the hands of hakan carlqvist.sand cast cases,power valve,round slide carb and radically shaped pipe.factory ohlins front and back with hand made aluminium swingarm.hubs are magnesium...and get this this is strange,disk on the front drum rear.......now ill try and scan this and put it on .....might have to get the misses to help.... ;D
any luck with scans ?
Offline Husky500evo
« Reply #17 on: September 22, 2007, 10:23:11 pm »
I have pictures of Carlqvist's & Leif Perssons YZM500s in my computer, but I don't know how to reduce them down below 128kb so I can post them. Any tips ? They are both air cooled , with a variable exhaust port & an exhaust pipe that also acts as an air scoop to direct air on to the top end.
« Reply #18 on: September 23, 2007, 08:16:39 am »
Husky500Evo,
i have  sent Email to you.
Offline paul
« Reply #19 on: September 23, 2007, 08:19:51 am »
can you email them here  and i will see what i can do  [email protected]
Offline VMX Andrew
« Reply #20 on: September 23, 2007, 08:50:27 am »
ive got the same problem too.... cant reduce the size to the 128kb limit.... ???
Offline paul
« Reply #21 on: September 23, 2007, 08:57:09 am »
some time if you email to you self you computer will auto resize them   ,save it to a folder  then do the photo bucket thing
« Last Edit: September 23, 2007, 08:59:42 am by paul »
Offline VMX Andrew
« Reply #22 on: September 23, 2007, 09:39:26 am »
finally here it is boys.....
[attachment deleted by admin]
« Last Edit: September 23, 2007, 09:41:59 am by Andrew vmx »
« Reply #23 on: September 23, 2007, 10:48:00 am »
Andrew, can you send them to me as they are directly please. [email protected]
« Reply #24 on: September 28, 2007, 10:28:42 pm »
I'll assume it's a KIPS and you I learn everyday.
Any pics Geoff?
Here you go Lozza, I finally found my old manual.
« Reply #25 on: September 29, 2007, 07:05:59 pm »
Yamaha had been running powervalves on their works 500's as early as '81........as featured in VMX a while ago with Gally's ow51.
« Reply #26 on: September 29, 2007, 08:03:36 pm »
Interesting!!!
What actuates the valve?Exhaust gas pressure or is there a rod from a governor off the crankshaft?
« Reply #27 on: September 29, 2007, 08:07:17 pm »
im glad someone mentioned Galls OW51. i knew i must of been right thinking that there was a powervalve yamaha back that early.
