Author Topic: suzuki speedo  (Read 5022 times)
Offline frostype400
suzuki speedo
« on: January 12, 2009, 08:39:49 pm »
Im after a suzuki speedo for my pe400 they have a brown face and trip meter they look very similar to ts speedo they go up to i think 160kms im looking to find the right one as i have correct bracket and cable so im ready to go when i find speedo thanks Michael. :)
1971 tm400 and PE's
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Ban BLACK rims NOW
Offline frostype400
Re: suzuki speedo
« Reply #2 on: January 12, 2009, 09:12:53 pm »
really after right one will check with leith if they are the same thanks Michael.
1971 tm400 and PE's
Re: suzuki speedo
« Reply #3 on: January 12, 2009, 09:29:10 pm »
casing is different. not sure if bolt centers line up with PE bracket.
closest one to real thing is a TS 250/400 speedo from around 76 i think. only a PE purest will know its not a PE speedo.
« Last Edit: January 12, 2009, 10:05:19 pm by LWC3077 »
Offline frostype400
Re: suzuki speedo
« Reply #5 on: January 20, 2009, 08:19:05 am »
Thanks i will be watching that thanks Michael. :)
1971 tm400 and PE's
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
Re: suzuki speedo
« Reply #6 on: January 21, 2009, 10:12:15 pm »
yep. according to Doc, it's the 75 and 76 that had the 21" front wheel. ie a bolt-on. A better trip-meter rewind too!
Offline frostype400
Re: suzuki speedo
« Reply #7 on: January 21, 2009, 10:14:50 pm »
Thanks luke will keep that in mind thanks Michael.
1971 tm400 and PE's
Re: suzuki speedo
« Reply #8 on: January 21, 2009, 10:17:19 pm »
the PE internals wont fit TS 250/400 case though. TS case has trip meter knob higher up. the only other suzukis i can find with exactly the same speedo cases as PE's is the T350 and T500. ive got a NOS T500 speedo in my hand now (that i bought just to get a good case/parts and to put PE internals inside) and if it just had a brown face with 0-160KM it would look identical to a PE one although most likely not calibrared right for 300x21 tyre.
« Last Edit: January 21, 2009, 10:23:27 pm by LWC3077 »
Offline frostype400
Re: suzuki speedo
« Reply #9 on: January 21, 2009, 10:24:50 pm »
ok so i just need to try and get this one on ebay and swap the guts into a t500 or something the brown face and trip look fine just the case and glass are a bit ratty but sounds as if there will be a solution i want to get that one first though i will have to see whhat happens the bidding will probably take off at the end thanks Michael.
1971 tm400 and PE's
Re: suzuki speedo
« Reply #10 on: January 21, 2009, 10:36:16 pm »
that one on ebay has me a little suss because im pretty sure that is about the 3rd time ive seen that speedo listed, not sure if its by the same seller or if previous buyers havent paid and hes re listing it?. the way i know is because of the 'spider crack'
« Last Edit: January 21, 2009, 10:37:51 pm by LWC3077 »
Offline frostype400
Re: suzuki speedo
« Reply #11 on: January 21, 2009, 10:51:21 pm »
what do you think i should do keep after it ask him what his go is if any one has one they dont need i would like one for my pe please pm me i am after one thanks Michael
1971 tm400 and PE's
Re: suzuki speedo
« Reply #12 on: January 21, 2009, 10:55:55 pm »
i dont know, maybe ask a few questions about its history? i tryed to find an old photo but didnt have one. i would just buy it and if you have issues there is ebay complaints thingy to go through, but im not sure this is same seller as before, it just could be some one new selling it. if you decide you dont want it let me know because then i will have a bid ;D
« Last Edit: January 21, 2009, 11:02:19 pm by LWC3077 »
Offline frostype400
Re: suzuki speedo
« Reply #13 on: January 21, 2009, 11:14:29 pm »
no worries i will let you know if i dont want it im going to try win it thanks  Michael.  :)
1971 tm400 and PE's
